My Woodin Roadster
Discussion in 'Motorized Tandems, Trikes and Recumbent Bicycles' started by plycar, Jan 29, 2016.
  1. plycar
    plycar New Member
    Aug 11, 2014
    58
    Hello,
    It's a year, since I began my second velocar project , so I want to show the results so far.
    The Roadster is not ready yet, but I hope to complete it in early spring.
    Recently I'm 50% through the construction of the front hood.
    Specs:
    Quadricycle
    Capacity: 2 adults (sociable) + 2 small childs
    Length: 300cm+/10ft
    Width: 113cm/3ft 8inch
    Height: Body 79cm/ 31inch, Soft top 115cm/3ft 9inch
    Frame weight: 15kg
    Chassis weight (with suspension/axle parts, complete wheels (2x NuVinci) and steering, transmission still missing): 37kg
    Overall weight: 65-70kg (I hope so)
    A hub motor instead of Nuvinci and Lifepo4 battery+controller may add 6-7kg
    Frame and body parts are build from 4mm Okoume/Gaboon plywood with spruce girders.
    [​IMG]
    The box frame, top panel still missing
    [​IMG]
    Mockup family ride and future body lines
    [​IMG]
    The chassis is standing on it's own wheels !!!
    [​IMG]
    Somewhat transformed Ackermann (or better Lankensperger) geometry
    [​IMG]
    Early stage of tail construction
    #1 plycar, Jan 29, 2016
  2. plycar
    plycar New Member
    Aug 11, 2014
    58
    Second row of pics
    [​IMG]
    [​IMG]
    Size comparison with a middle class estate
    [​IMG]
    Determining the shape of the front hood
    [​IMG]
    Drawings of different body versions
    [​IMG]
    Sides cutted and clamped in place
    #2 plycar, Jan 29, 2016
  3. plycar
    plycar New Member
    Aug 11, 2014
    58
    [​IMG]
    Dashboard frame is glued
    [​IMG]
    Future front luggage compartment
    [​IMG]
    A first test with cheap poplar plywood, to control the right shape. Thanks Steffen
    [​IMG]
    Knee clearance is a bit tight, I have to shift the dashboard 5cm forward
    [​IMG]
    Additional cutouts for the knees of the riders.
    I'm dreaming about a very old brass clock in the middle of the dashboard
    #3 plycar, Jan 29, 2016
  4. racie35
    racie35 New Member
    Nov 17, 2012
    1,698
    I like it !
  5. curtisfox
    curtisfox Active Member
    Dec 29, 2008
    3,762
    Ya that's Kool ,like it.............Curt
  6. racie35
    racie35 New Member
    Nov 17, 2012
    1,698
  7. Agreen
    Agreen New Member
    Feb 10, 2013
    784
    This is what I've dreamed of doing since I was a kid. I'll be following along on this. Thanks for sharing!
  8. silverbear
    silverbear The Boy Who Never Grew Up
    Jul 9, 2009
    8,172
    Very cool project...
    SB
  9. xseler
    xseler Active Member
    Apr 14, 2013
    2,538
    I could see Anne (Intrepid) breeze'n down the street in a flapper hat!!
    Look's great! Paint the rear arch a different color and call it "Dela-Hey-Hey"!! :D
  10. plycar
    plycar New Member
    Aug 11, 2014
    58
    Thanks for your comments.
    My favoured paint scheme is green, black and wood.
    Most edges of the body will be painted dark green after filling all screw holes.
    I want to paint black lines on the borders between green and clear finished wood.
  11. fasteddy
    fasteddy Active Member
    Feb 13, 2009
    5,179
    Hello plycar,
    Great to see you back. What a wonderfully thought out build once again. Thank you for sharing it.
    Steve.
  12. wheelbender6
    wheelbender6 New Member
    Sep 4, 2008
    3,782
    That's really cool. Your steering setup looks well designed and very adjustable. I would like to build something similar, but with only three wheels to maintain street legality.
  13. plycar
    plycar New Member
    Aug 11, 2014
    58
    Luckily, here in Germany the number of wheels of an E-assisted pedal vehicle doesn't matter at all.
    A guy from Berlin has built an eight-wheeled pedal truck with E-motor and can drive it legally in traffic.
    http://www.nicojungel.net/space.html
    In the UK, they changed the law in mid 2015 and E-quadracycles seeming to be legal now.
    I don't have understood completely the new UK-regulation, due to the bureaucratic English language, I even have problems to read bureaucratic German :D
    In case of the US, it may be almost impossible to have booth four wheels and E-assist in a legal pedal vehicle.
    But as I learned, the regulations differ from state to state, right?
    #13 plycar, Jan 31, 2016
  14. plycar
    plycar New Member
    Aug 11, 2014
    58
  15. wheelbender6
    Sep 4, 2008
    3,782
    "But as I learned, the regulations differ from state to state, right? "
    There is a National law in the USA legalizing 4 wheel, electric vehicles regulated to 20mph or less. If you are capable of better than 20 mph, better to have three wheels to be considered a motorcycle. Otherwise, you will need 5 mph bumpers, air bags, and lots of additional safety equipment.
  16. plycar
    plycar New Member
    Aug 11, 2014
    58
    A short building update:
    [​IMG]
    [​IMG]
    Door frames glued and doors finally cut out.
    With outside hinges they will be able to swing 180°, as shown
    [​IMG]
    [​IMG]
    Top panel temporarily attached and edges partly trimmed.
    [​IMG]
    The hole in the front will be closed by the head lights and a "hood", next weeks main issue.
    Due to my trial&error building method this will take some time.
  17. silverbear
    Jul 9, 2009
    8,172
    Coming right along! Looks like somebody is waiting for a ride...
    SB
  18. plycar
    plycar New Member
    Aug 11, 2014
    58
    Thanks, SB and yep, looks like :)
    But, as I know Banshee, she'd rather run beside the velocar, than sit in it.
    Maybe after a few miles ;)
    Tomorrow I will do further work on the velocar.
    I was not able since last Thursday, because of a severe cold.
    A lot of functional stuff is still to do.
    Steering column,handlebar, brakes and transmission.
    The design is nice so far (IMHO), but worthless without all that.
    I hope in early spring I can do my first test rides.
    Kai
  19. Allen_Wrench
    Feb 6, 2010
    2,786
    I'm likin' this. It's looking pretty cool already. I'm going to follow this.
  20. 2door
    2door Moderator
    16,286
    Those 'gull wing' doors are just too cool. Keep the progress photos coming. They're much appreciated and enjoyed.
