My wife wants a motorized tricycle...
Discussion in 'Motorized Tandems, Trikes and Recumbent Bicycles' started by ImMrFixit, Aug 29, 2014.
  1. ImMrFixit
    ImMrFixit New Member
    Aug 6, 2014
    9
    Is there a specific type of engine kit that needs to be purchased for a tricycle? My wife has decided that she wants one. She's looking at the Schwinn Meridian. Anything I should do or know in advance? Thanks
  2. 2door
    2door Moderator
    16,285
  3. Bldr1000
    Bldr1000 New Member
    Aug 26, 2013
    22
    I just installed a Harbor Freight 212 cc 6.5 HP engine on a Schwinn Meridian. I used a max-torque centrifugal clutch with 10 tooth sprocket pulling 56 tooth drive sprocket with #41 chain. That bike will almost idle at 20 mph. I got to attach a torque converter and gear it down. The bike is not that stable to start with and I got way to much motor on it. I would suggest a harbor freight 79 cc engine with a torque converter. It would be plenty to pull your bike around. I have 3 other two wheel bikes with engines on them and they are very stable, but the trike scares the bee gees out of me. Bldr1000.
    #3 Bldr1000, Sep 2, 2014
  4. racie35
    racie35 New Member
    Nov 17, 2012
    1,698
    That bike lends itself well to electric... Easy to carry the batts etc
  5. LR Jerry
    LR Jerry New Member
    Dec 19, 2011
    1,028
    You can contact Staton Inc. David has some book trike setups. KC Vale is really good with trikes also.
  6. racie35
    racie35 New Member
    Nov 17, 2012
    1,698
    I'm doing a simplex but its nothing like that
  7. racie35
    racie35 New Member
    Nov 17, 2012
    1,698
    Here's a few pics
  8. racie35
    racie35 New Member
    Nov 17, 2012
    1,698
    Having trouble uploading but here's another
  9. TomyJ
    TomyJ New Member
    Jul 24, 2014
    My local bicycle shop will not sell/build Schwinn Meridian, they say the frame/rear axle will not withstand the higher speed, they sell/build Sun Trikes from Florida and a nice big basket in the back :>)
    If you go electric stay above 350 watts and 36 volts, If you go gas stay close to the 100cc
    but also remember MB rules are for 2 wheelers, NOT 3 wheels according to Ca. DMV Motorcycle Handbook :>) Yeaaaaaaa !!!
  10. Bldr1000
    Bldr1000 New Member
    Aug 26, 2013
    22
    Well, I made new mounting plate, extra strength, installed comet torque converter, 10 tooth pulley pulling #41 chain to 56 tooth sprocket on 26 inch wheel on Meridian Trike as stated above. I cannot keep the large 41 chain on the 56 tooth sprocket, it keeps creeping over the top and off. Its dangerous. Why do they make the 56 tooth sprocket so skinny. If it was thinker the chain would probably stay on. I first used a Centrifugal clutch and chain stayed on but clutch was not strong enough. Any ideas why it wont stay on? I have adjusted andm lined this thing up a bunch of times.
  11. racie35
    racie35 New Member
    Nov 17, 2012
    1,698
    Is the sprocket warped? That's always fun. Make sure nothing is moving axlewise or flex on the chassis and engine mounting also.....doesn't take much torque to move things around if they're not rugged enough
  12. Bldr1000
    Bldr1000 New Member
    Aug 26, 2013
    22
    I'm not giving up just yet. I'll check the flex and the sprocket again. It seems to be running true, and the torque converter may be flexing some since I moved the drive gear to the outside of the shaft.
  13. racie35
    racie35 New Member
    Nov 17, 2012
    1,698
    Engine mounting maybe..that and frame flex
  14. Jim C
    Jim C New Member
    Jul 11, 2010
    190
    I built a Schwin 3 wheeler with a front wheel electric motor and battery pack in the rear basket for my girlfriend. She rides it everywhere and has never had a problem. The thing is plenty strong.
