my journey begins
Discussion in 'Motorized Bicycle General Discussion' started by MacZulu, Jul 8, 2015.
  1. MacZulu
    MacZulu New Member
    Jul 3, 2015
    127
    thanks Chaz, I'll probably you up on that. I was thinking of making an exhaust gasket as close to the ports shape as possible, and not even use the given stock gasket.
    would doubling up with a homemade and a trimmed stock gasket work?
    #41 MacZulu, Jul 17, 2015
  2. MacZulu
    MacZulu New Member
    Jul 3, 2015
    127
    so I need to try clean up by hand and dremel all theses locations?
    some tricky reach there, I read the bent xacto blade technique.
  3. Legwon
    Legwon New Member
    Mar 2, 2013
    248
    if the gasket is actual metal, it should be fine to grind it out to shape, with a dremel or the like.
    for porting the intake and exhaust, its waaaaaaaaaaaaay easier to do it from the outside of the jug.
    the transfer ports... not so easy. :s
    i dont have a method to do them as of yet, the tools i use are works gear. and the die grinder bit is much too large for them. works great for the bottom end though.
    gotta watch WHERE you take off , and how MUCH you take off the intake and exhaust... they WILL effect the operation of the engine!!
    speaking of bottom end... thats where a lot of the bottlenecking comes from.
    at very least, match it to the jug.
    easiest way to do so is to split the case, and match jug. each side.
  4. MacZulu
    MacZulu New Member
    Jul 3, 2015
    127
    ok, so Davezilla gave me a suggestion after answering my question in another thread. So I followed his suggestion, but I'm bringing it back to this thread as it is more relevant to my "journey" as this thread title alludes too.
    Thanks Davezilla, I have started trimming the skirt for the intake outlet. I wasn't sure about what you meant with the 5mm, so I scribed the overhang section of the skirt and removed it. It was slow going as I still can't sit for long stretches, so a lot of breaks. I don't know how perfect the match is yet, as I don't want to put it into the sleeve until I clean up my sloppy scuffs (should have taped it off). pictures show what I mean.
    on a side note, I looked at breaking the crankcase open. one of the two flat head screws that basically go through the front mount started to slip, so I stopped. I might just need a bigger screwdriver for better
  5. MacZulu
    MacZulu New Member
    Jul 3, 2015
    127
    trying to clean up the transfer ports. I'm done for the day, but I'm not finished on them.
    there was a pronounced lip on the ports. here's one of them before and after.
    at the top side there was alot of pitting and roughness.
    I'm just trying to smooth out the surface.
    My main reason for all this work is I cant ride right now anyways, and I would like to improve the smoothness (vibration) of the engine.
    and it is alot of fun.
  6. Davezilla
    Davezilla New Member
    Mar 15, 2014
    2,708
    Nice job on the poston, those little scuffs on the piston skirt aren't that bad and can be fixed by removing any high metal with a jewelers file or some fine sandpaper, just need to remove any metal that protrudes above the surface, the indentations won't hurt anything. If there was a deep scratch tho, it would need to be blended out but those little nicks won't hurt it.
    The lower transfer openings are looking good too
  7. MacZulu
    MacZulu New Member
    Jul 3, 2015
    127
    Thanks, I will check the scuffs and make sure their flush. I also wanted to split the crankcase open, but one of the flat head screws at the front mount is slipping. I want to match the ports, so I need to figure out something. intake/exhaust as well, and some other sloppy clean up.
    I wanted to ask what grease, if any and where to apply it in the rebuild phase?
    it's alot of work, but I'm enjoying the whole process.
  8. Davezilla
    Mar 15, 2014
    2,708
    As far as greasing certain parts during the rebuild process, about the only parts that need grease are the bevel and clutch gears, the clutch cam and the bucking bar and ball, you'll get all kinds of opinions on marine grade, Lucas red n tacky, moly greases, and lithium greases.... Of all the ones I've tried over the years, my preference is Kendall super blu, it's a lithium complex grease that's water proof and it's not super sticky like the red greases but it stays put just as well. This stuff works great for the gears and the clutch parts like the clutch cam, bucking bar and ball. If you prefer the red sticky grease, it does work good on the gears since it stays put and it's really thick so it helps quiet the gears a little, but the gears will usually quiet down on their own after the bike has been run for about an hour or so.
    You don't need a lot of grease on the gears tho and it can't come in contact with the clutch pads, just a small dab on the gear and it'll spread over all the teeth quickly once run.
    This is the stuff I use on everything from the bevel gears and clutch parts as well as the brake and clutch cables on these bikes to the bearings in high end cars or heavy duty trucks... it's just a really good all around grease, it's waterproof, it stays put, and it protects the parts very well, even after 30k miles in a bearing it still looks like it was applied yesterday... http://www.petroleumservicecompany.com/kendall-super-blu.html the stuff can be hard to find sometimes but I get it off eBay in 1lb tubs for about $6 per tub and a 1lb tub will last about 3 to 6 months at the shop so it would last year's in one's garage...
    Here's the ebay link I get it from if interested... http://www.ebay.com/itm/141658016531?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    There's no need to grease anything inside the engine but a thin coat can be applied if an engine is to be built then stored for a really long time to prevent corrosion, it'll keep things like new until the engine is ready to use then the fuel/oil mix will wash it out as the engine runs for the first few minutes, this step isn't needed unless the engine has to sit for several months unused in a very humid environment. Otherwise just a small amount of motor oil on the bearings and rings will be ok, the motor oil will stay put and protect the bearings etc for several weeks inside a closed engine. Some people will spray a shot of wd40 into the cylinder before starting for the first time just to lube the rings until the fuel oil mix can get in there.
  9. MacZulu
    MacZulu New Member
    Jul 3, 2015
    127
    Alright thanks for the info, I'll check out the links and go from there. I'm surprised we don't use any on the cnb, so I'm glad I asked.
  10. MacZulu
    MacZulu New Member
    Jul 3, 2015
    127
    So I have continued on with BarelyAWake's sticky and went after the exhaust port. I also started cleaning up the exhaust as well,although I will probably replace it with a motorcross poo poo exhaust. apparently they are not as loud as others, and I like the idea of it being behind me.
    the exhaust port was not so fun, but I'm pretty much there. it was pretty ugly before, as you can see
    so started with the little steel etching bits, then small drum. all the sandpaper drums in the kit are probably 80 grit, no markings and seemingly no coarseness difference. I had the dremel right in the throat (after taping off most of the port) to reach the back corner. then 50 grit with a sharpie and chopstick mostly. then 80, 150, 400 just alittle.
    so I appreciate the sticky, and the members here for making this journey a lot less trial and error. and more interesting, i never would have gone after the little engine with a dremel with out the explanations and pics.
  11. Davezilla
    Mar 15, 2014
    2,708
    That exhaust port looks Nice!!
    Good job... did you measure how wide it is in the cylinder and at the outlet?
    That's one of the better looking ports ive seen in here for sure, just be sure to keep it 29mm or less to prevent any chances of ring snagging. Not sure if you read about the 60% rule, but it means that as long as you don't go more than 60% of the bore diameter you wont run the risk of snagging a ring. You can also raise the port roof by 1mm for more rpm,but use a spare piston and ramp it to see how it performs before raising the roof higher. Basically, ramping the piston does the same effect as raising the port roof so its a good way to experiment without going too far on a cylinder. Mine usually come out where I want them with the roof raised about 2mm but that's also really close to where it effects the low rpm torque more and more.
    Ramping the piston at the transfers is the best way to get more transfer duration since raising the transfer roofs effects blowdown and will take away low rpm performance because of residual exhaust pressure can push the fresh intake charge back down the transfers if the roof is too high, this can be remedied to a certain extent by case stuffing but really good performance can be had without stuffing the case by keeping track of the blowdown and not going too excessive so ramping the piston at the transfer openings only is an easy alternative, more power can still be had by stuffing the case but as long as your not too greedy with the transfer duration you can get away with excellent performance and not have to stuff the cases to prevent the exhaust pressure from overcoming the transfer pressure. A nice wide exhaust port like what you did also helps bleed off this pressure well before the transfer ports are exposed.
    You're definitely doing a good job with it so far. If you have a degree wheel and a dial indicator that'll help you set the cylinder at just the right hight for best port timing and duration when you get closer to ready to put the cylinder back onto the bottom end... I have a few posts in here showing how I made the degree wheel and mount it to the crank but we can go over that when you're ready.
  12. MacZulu
    MacZulu New Member
    Jul 3, 2015
    127
    thanks man. I was just trying to clean it up, I wasn't really thinking of power. I think I'm ok, just a tad under 28mm I think
    and don't touch the intake port, roughness aids atomization fuel:air so on and so forth. or something like that. when I measure the intake stud gap it's 40mm, so I take it that the engine has a "40mm intake"?
    piston ramping does scare me a bit, maybe not this build. I would definitely want a spare piston on hand, but I will try it eventually. now I have the tools to do it.
    what my main goal with this build is to help this little china doll run as smoothly as it can. reduce noise and vibration are my biggest concerns. I also want some low end on this engine because I live on top of large hill, it's a large plateau really. but it has some nasty hills leaving in all but one direction where the grade is more gradual. so I'm going with the 44 t sprocket that came with the kit to start with.
    I'm also interested in the port timing of which you speak, I've seen comments here and there referencing it. so I will take you up on that offer when the time comes, if convenient.
    now I'm just waiting on a new gasket set, then I'll bore out the exhaust. Still haven't managed to split the crankcase, I would like to clean it out and match ports. I have read about using jb weld for stuffing the case to increase compression, but I wasn't planning on that this build. It's really depends on how quickly my back gets better to the point where I can ride my bike. then I'll want it mounted and running.
  13. Davezilla
    Mar 15, 2014
    2,708
    Yeah, the wide ports are good for making lots of torque...
    You can do the intake but leave the surface rough... 80 or 100 grit sanding drum will leave a rough enough surface or just use the rotary files and don't polish which leaves a rough enough finish.just widen the intake 1mm on each side for excellent torque. You can also shave down the head using the sandpaper on glass method or if you got a belt/disc tabletop sander it'll make short work shaving down a head. I did a customer's engine by just widening the intake and exhaust ports then shaved down the stock head for better compression and better gasket sealing and that engine was a torque Monster... strong enough to slip the clutch on pavement or spin the wheel on dirt or gravel. The top speed was around 30 mph but the torque and acceleration was awesome.
    Also, for good torque there's no need to raise the exhaust port roof or ramp the piston at the exhaust port, if you already did this tho it wont hurt since that exhaust port is nice and wide. You'll also want to sit your cylinder closer to the bottom end by using a thinner base gasket so the port duration is narrow but the air can get into and out of the engine in large volumes. A straight pipe that's longer will also help make lots of torque so you can extend the stock pipe or get onenof those really long poo poo pipes, this will also make the ride quieter since the noise will be behind you, and using a stock type muffler with 4 extra 5/16" holes drilled into the end cap will help make torque as well as keeping things quiet since we're not going to mess with the internal baffling.
    if you choose to use an expansion chamber pipe you'll want a nice long header to keep the power down low. You can get a lot of torque out of these engines by using these tricks while keeping it nice and quiet, and still be able to do at least 30 mph or so on top.
  14. MacZulu
    MacZulu New Member
    Jul 3, 2015
    127
    that sounds good there about the torque monster, I was thinking about that glass wet sanding technique. how long do you do it for? what grit?
    I also have an ngk plug that is quite a bit longer than the stock, so that should increase compression. I will take a look at the intake port tomorrow, that doesn't sound too bad. I have a new set of gaskets coming, hopefully nice and thin. I already have dreams of an 18mm mikuni, but for now I will go with the stock carb.
  15. Legwon
    Legwon New Member
    Mar 2, 2013
    248
    well well.. you been busy mister!! haha!
    looks great! keep it up :O)
    ok, so first.... DONT .. i repeat DO NOT get the motocross poopoo pipe.
    it is HORRIBLE! i had one, put it on... lost all tourqe, and top speed. And the back pressure blew out both seals. its only MAYBE 1/2" hose all the way thru.
    to lap the head and jug top...
    https://youtu.be/cQHdXcqAo-k
    and watch the length of the spark plug. especially if your running a 40mm stroke engine. dont wanna smash the head off on first start :(
  16. Davezilla
    Mar 15, 2014
    2,708
    I agree about the spark plug... better to get the compression from shaving down the head or getting a high compression head and stick with the proper plug... a piston can hit a plug that's got too much reach.
    As far as the poo poo pipe... if its a small diameter pipe then it could do more harm than good...the stock pipe does perform once the end cap has extra holes drilled, but also the flange on the stock pipe leaves a lot to be desired as the hole in the flange is even smaller than the stock exhaust port in the head. Ive port matched stock pipes which helps bring them around but the opening can only be brought up to the pipe's inner diameter or just slightly more if the weld is thick enough.
    A straight pipe can also be fabricated out of 1˝ emt tubing (electrical conduit tubing) to give the pipe length and get the noise behind you, this will require welding or brazing a flange to the pipe or to splice the stock pipe in. The longer pipe will also contribute to more engine torque, and a longer intake will make more torque as well, but at the cost of some top end rpm.
    Just using the stock pipe with extra holes in the end cap is an easy way to get better torque from the engine too, and a tuned expansion chamber would give the best gains but a straight pipe tuned to the right length can work quite well...
  17. MacZulu
    MacZulu New Member
    Jul 3, 2015
    127
    Thanks Legwon. I have been busy, and i did it with out sitting down. But it is aj enjoyable process.
    Bummer about the poo poo being crap (coincidence? ), I had read good thing about it, but I'll heed your advice and seek other options.
    So ideally if I replace the stock muffler it should be with one that has the same size pipe?
    And I'm guessin the hard pipe poo poo is also too restrictive. Well once the engine is together I will probably play with the shock muffler as per your suggestion Davezilla.
    I will look at my head and plug later when I get home and check the clearence again. I did before and I think it's ok, plus alot of people are running ngk plugs no problem, no?
    And as far as my crankcase goes, I'm starting to think I should strip the screw head enough to use my stripped screw removal bit. It's shaped more for Robertson and Phillips stripped, so a flathead is a little more challenging. I don't think I'm up to drilling out the screw and retapping the hole. There's always a pia when doing projects.
    thanks for the input, every bit helps.
  18. Davezilla
    Mar 15, 2014
    2,708
    For the stripped screw head, you can most likely coax it out if you have an impact driver. You can get one with a bit set from most auto parts stores for fairly cheap, just make sure it's set in reverse before striking it with the hammer. This tool is a very good investment for anyone working on these or on motorcycles... or basically anything that's aluminum or die cast metal that has standard or phillips screws holding it together...
    As for the pipe, that bike I built for a customer, I just used the stock pipe but drilled 5 5/16" holes thru the end cap and didn't even mess with the inner baffles. The engine was still nice and quiet after the holes were drilled but the torque was amazing combined with the mild port job I did, that engine was basically ports widened 1mm on each side of the intake and exhaust ports, head shaved down 1mm, casting ridge removed from transfer roofs, and I ramped the piston at the transfer openings only and cut 5mm off thte skirt on the intake side... took me all of about 30 minutes to do the port work, I didn't want it to be a screamer but since this customer was on the heavy side I did want better torque, but didn't expect it to make the crazy amount of torque it did, I was expecting it to be a little stronger but it turned out a LOT stronger and was still able to get above 30mph on top.
    Yours should have similar or better torque with that really wide exhaust port if you can also get similar compression
  19. MacZulu
    MacZulu New Member
    Jul 3, 2015
    127
    I will grab that impact set, that's a handy thing to have for sure. and I will do the 5 holes at 5/8" in the muffler end cap. both good tips, I am itching to split the case.
    I was out with the family this afternoon and we were near the store where I bought the kit, so I grabbed an extra piston. I will take a shot at ramping the head at the transfer opening, in for a penny in for a pound I guess.
  20. MacZulu
    MacZulu New Member
    Jul 3, 2015
    127
    as for the spark plug, here's how it looks hand tight
    so I think the clearance looks good. and look at how much thread is left unused by the stock plug. looks like the head is designed for the full size plug
