My back wheel bearing exploded!
Discussion in 'Motorized Cruiser Bicycles' started by artcfartc, Oct 3, 2011.
  1. artcfartc
    artcfartc New Member
    Aug 17, 2011
    6
    While driving my Op Cruiser home from work at about 30mph, my back wheel locked up. Thankfully I didn't eat it, and no-one was driving behind me. I'm also very lucky that my wife answered the phone and came to rescue me so I didn't have to carry my bike all the way home. I first thought that the chain had jammed, or the clutch had gone out, but no, one of the bearings in the back wheel exploded or melted (see pic). I had only been going 30mph off and on for about 10 minutes. Has this happened to anyone else?
    I replaced the back wheel with a '60's Bendix brake cruiser wheel knowing that it would take more abuse, but I'm still a little scared of using my bike for transportation. Are there any more measures I should take to insure that this NEVER happens again?
  2. artcfartc
    Aug 17, 2011
    6
    Here's the pic. It didn't upload 1st time. Also tech specs. I'm running a 60-80cc 2 stroke engine kit of unknown origin.
      File size:
      109.4 KB
      300
  3. flatblack
    flatblack New Member
    May 22, 2011
    374
    Lucky you didn't go dirt-tracking down the road like I did when mine locked do to pull brake wedging between the frame and tire. Glad you're all right!
  4. happyvalley
    happyvalley New Member
    Jul 24, 2008
    786
    The 1/2 fried caged bearing, where is that from?
  5. artcfartc
    Aug 17, 2011
    6
    It's the outer bearing on the back wheel. I think it was the side with the brake arm and the gear for the motor.
  6. Fulltimer
    Fulltimer New Member
    Aug 13, 2010
    1,322
    About the only thing I can think of is to repack the bearing often. Keep a close eye on it until you get an idea of how often you need to repack it. Your back wheel and my front brake & fork. No fun is it!
    Terry
  7. whelan wheels
    whelan wheels Member
    Jan 9, 2009
    170
    I noticed that your using bearing cages. If you get rid of the cages and free float your bearings you'll never run into that problem again, just make sure that you pack it well with good quaility bearing grease and you should be ok. Thats what i do with all of my rear wheel bearings, never had a failure yet with that system.
    xct2 cflg
  8. cory151
    cory151 Member
    Oct 19, 2010
    466
    Whered you source the free floating bearings?
  9. whelan wheels
    Jan 9, 2009
    170
    You just remove the bearings from the cages and put them in the races,but make sure that you pack grease in the races first then place the bearings in after because the grease will hold the bearings in place. Then place your axel through and after that your cones and you should be good to go. I guess the term is bearings that ride with out a bearing cage are often called free floating bearings.
    xct2 cflg
    #9 whelan wheels, Oct 3, 2011
  10. Greg58
    Greg58 Well-Known Member
    May 1, 2011
    2,937
    90
    I have a o/p that has over 600 miles on it with no wheel bearing problems, I cleaned and repacked the bearings with a very high quality industrial grease called alithicon. We have used at work for about 20 years now, it keeps bearing failures down because it lowers the temp. of the bearing.
  11. happyvalley
    Jul 24, 2008
    786
    Loose ball, but leave one out. Check the races for wear, adjust preload carefully then check again for play after mounted on the bike.
    In the original pic of the failed bearings, the grease looks pretty contaminated. At the speeds I see some talking about riding I'm surprised this isn't happening more often.
  12. artcfartc
    Aug 17, 2011
    6
    If I free-float the bearings, I'll need more bearings to fill in the gaps that are created, right?
  13. whelan wheels
    Jan 9, 2009
    170
    Yeah , probably you'll need at least 9 per side is the usual count , depending on the type of hub your using.
    xct2 cflg
  14. Mannhouse51
    Mannhouse51 New Member
    Jun 2, 2011
    277
    I had that happen to my rear wheel last summer , it REALLY sucked! Now greasing the wheel bearings is on my preventative maintinence list. Once a month I clean and pack the bearings, clean the air cleaner , etc. No problems since. I've been using a blue wheel bearing grease by Mag1. It's waterproof and works well.
  15. cuberasnapper
    cuberasnapper New Member
    Feb 22, 2011
    58
    just buy a good rear wheel and ride out with no worries
  16. happycheapskate
    happycheapskate New Member
    Nov 26, 2009
    1,990
    That's awful. Glad you are ok. I think it may be possible that the cones were too tight in your wheel. I agree, loose-ball bearings are good, no cage to deform or interfere. The cages are used to simplify assembly and maintenance, since coasters are generally used on low speed bikes that won't see a lot of use or maintenance.
  17. Saddletramp1200
    Saddletramp1200 Custom MB Buiilder
    May 7, 2008
    1,421
    The bike was made to go 15-20 tops. They put some brown stuff on the bearings that could be grease. Very little of it . I call china bearings buckshot, they go boom! I'm gald it was the back wheel. Check your wheel bearings often. Like every week! You don't it can be E.R. time. (c)
  18. FarRider
    FarRider New Member
    Jun 8, 2011
    134
    Whoooo Hoooo! bet that scared ya.
    Now THATS a catastrophic bearing failure!
    I gotta hand it to ya... when you break stuff you do it with style.
    I agree with Whelan, loose the bearing cages and use high quality grease.
    Was it a coaster brake hub? those generate alot of heat.
    FR
