Must petcock be attached to tank?
Discussion in 'Motorized Bicycle General Discussion' started by atombikes, Oct 22, 2013.
  1. atombikes
    atombikes New Member
    Feb 14, 2010
    525
    Is it possible to remotely mount the petcock away from the tank? Like attach a fuel line to the bottom of the tank with a hose clamp, then run the fuel line to a remotely located petcock? I have an interference issue between my desired tank and frame and am wondering if mounting the petcock remotely is OK.
  2. FMB42
    FMB42 New Member
    Sep 27, 2013
    107
  3. racie35
    racie35 Active Member
    Nov 17, 2012
    1,700
    close to the tank removes the chance of a leaking line draining it by accident.
  4. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,711
    80
    also, having it on the tank means not having to drain tank just to do any work with fuel line
  5. soup325
    soup325 New Member
    Dec 11, 2010
    175
    also, having it on the tank means that (2 stroke) oil wont settle at the lowest part of the fuel system.
    I had the petcock after the fuel filter. which meant that after about a month of not riding the bike, oil started to separate and collect in the fuel filter. this creates an uneven fuel mix in the fuel filter and this makes starting the engine very hard as there is too much oil in the fuel mix.
