Muffler discoloration
Discussion in 'Motorized Bicycle General Discussion' started by FlyingHorse87, Jun 30, 2010.
  1. FlyingHorse87
    FlyingHorse87 New Member
    Jun 27, 2010
    24
    I'm breaking in my engine and the chrome muffler is discoloring or "blueing". I know from motorcycling that exhaust blueing means the engine is running too rich, but is it running rich from the 16:1 petrol/oil mix or does the carb need adjusting? My idle screw is about 4 turns out, the side is about 1/8" from the bottom of the carb body. Could it just be the cheap chrome plating burning off?
  2. nidyanazo
    nidyanazo New Member
    May 25, 2010
    316
    The change in color is normal.
    To see if it's running rich, do a plug chop.
    That's where you run the bike at full throttle (or part throttle, whatever rpm range you want to check) and then kill the motor.
    Pull the plug and check if it's dark and wet (rich), white and burnt (lean), or just right with a nice brown tint/
    #2 nidyanazo, Jul 1, 2010
  3. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
    If you are talking about a China 2 smoke? That screw on the side is for idle adjustment. It will not change you air to fuel. You can move the clip up and down on the needle valve.
    #3 Goat Herder, Jul 1, 2010
  4. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    Good advice - 'cep ya wanna let the motor cool down before trying to remove the spark plug as you may pull the threads out of a hot motor ;)
  5. FlyingHorse87
    Jun 27, 2010
    24
    Thanks everybody, my plug isn't soaked so it's running fine.
  6. Venice Motor Bikes
    Mar 20, 2008
    6,170
    Use 24:1 for the break in!! 16:1 is too much oil!
    & "yes", 16:1 will cause it to run leaner.. More oil = less gas in every drop that goes through the carb & into the engine! ;)
  7. kicking
    kicking New Member
    Apr 11, 2010
    403
    I see a lot of that blue discoloration f/h ... I was thinking about red or black muffler paint.
  8. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    When I took my muffler apart I noticed that the area that turns blue is just past where the catalytic converter is so I'm thinking it more the heat from that then anything.
  9. kicking
    kicking New Member
    Apr 11, 2010
    403
    yep its more than likely from heat ,,, thats why if I paint mine it will be ,,, im thinking about white ,,,it has got to be muffler paint though to stand up to the heat ,, i painted the manifold and tail pipe on my van with some i bought from carquest because of rust,,,, looks good!
  10. FlyingHorse87
    Jun 27, 2010
    24
    Yes, I need to cut the mixture back. The instructions stated to run 16:1 for the first two tanks! That seemed like way too much oil, it drips and smokes like crazy.
