Mounting a Chain Tensioner
Discussion in 'Motorized Bicycle General Discussion' started by Xiodinc, Mar 6, 2010.
  1. Xiodinc
    Xiodinc New Member
    Oct 15, 2009
    171
    And getting it to stay in place! What do you guys do with the stock tensioner to get it in place?
    I was thinking some drilling and self tapping screws.
  2. bairdco
    Aug 18, 2009
    6,401
    49
    i've never had mine move yet.
    they stay just fine in the garbage can...;)
    sorry, can't help you. just messin' around.
  3. Ulysys
    Ulysys New Member
    Apr 25, 2009
    60
    I've seen a few bikes that have a screw through the tensioner bracket and chainstay tube, and it seems like it would be fine. I would jsut make sure it wasn't too big of a screw so you don't compromise the strength of the chainstay.
    I don't suggest doing what I did with my bike by accident, which was tightening the bracket so much that I pinched the chainstay tube :). It worked and the bike still seemed sturdy enough, but don't do it :).
  4. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    Not to discourage discussion but as the dreaded tensioner and it's mount is somewhat of a safety issue - I hearty suggest checking out the link posted above.
    Drilling holes and self-tapping screws a valid solution and used successfully by some - it, like all "suggestions" in that thread depends heavily on the bike in question. Depending on the gauge fastener used it could compromise the integrity of the chainstay - I'd not be comfortable doing that to my aluminum build for example.
  5. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,650
    66
    LOL Ulysys. I have done that and worse. Reshaped a down tube with a mallet, relocated a muffler to clear the crank with steel toed boots an' many more. Some times ya really do just need a bigger hammer.
    ...But don't do it! snork
    laff
  6. stilldoc
    stilldoc New Member
    Sep 16, 2009
    29
    You might try inserting adding a grab strip between the chainstay and tensioner bracket to prevent rotation without drilling a hole in the frame. It also allows for adjustment if necessary.
    Alternatively, you can use an internal tooth washer. Here's a photo of both.
    [​IMG]
  7. TheE
    TheE New Member
    Jun 26, 2009
    187
    I just made my stock tensioner really, really tight. It doesn't shift at all.
  8. Kevron99
    Kevron99 New Member
    Aug 11, 2009
    261
    If it is possible not to use the chain tensioner...I would not put it at all.
  9. lazieboy
    lazieboy New Member
    Sep 5, 2009
    51
    If motor is twisting a little with torque may cause it to move, or out of round sprocket causing chain to get real tight might make it move. Thats what happened to me, all better now. I also put an extra nut on the end of tensioner bolt nut to keep it from coming loose.
  10. lazieboy
    lazieboy New Member
    Sep 5, 2009
    51
    Put tensioner below chain pushing up on chain this is another thing i did to fix my issue with tensioner.
