Motorized bike seems to have more power at very slight choke
arguevera
11
29
Hi I have a default ebay 2 stroke 80cc kit with the stock NT carb.
Currently I have the pin in the carb set to the leanest setting (towards the top) as all the other settings seem to give some form of 4 stroking.
When I start the bike I choke it for around 5 seconds then immediately switch to completely open.
The bike idles perfectly fine when cold or when warm so I don't suspect any air leaks.
However I have noticed something peculiar:
If I have the choke ever so slightly closed, I have a significant power boost both in acceleration and in climbing hills. It doesn't seem to 4 stroke and idles perfectly fine.
So my two questions are as follows:
Is it okay to run the bike at this choke setting like this?
Is there any adjustments to the carb that I am missing out on?
crassius
4,032
158
USA
I'd try upping the float level a bit and see what happens if the motor has a couple hundred miles on it (I never do fine tuning until rings are well seated).
  • Like
Reactions: arguevera
