Motorized Bike/Parts and such.
Discussion in 'Motorized Bicycle General Discussion' started by JRalstin, Jul 26, 2012.
  1. JRalstin
    JRalstin New Member
    Jul 26, 2012
    hello, everyone! im new here and im not sure where to start. first of all, i dont know where to find the list of all parts to install the motor on the bike. i dont want the kit, just by getting a engine, clutch, drive chain and etc (must be 4 stroke). i tired many different sites, none of them will tell you what parts to get. hope one of you guys know where to look up. many thanks. .wee.
  2. 2door
    2door Moderator
    Staff Member
    16,304
    29
    Welcome.
    Not quite sure what you're asking. You want all the parts to install an engine but not a kit? I think you'll find that purchasing the parts seperate will cost you more than the kit.
    You might want to spend some time reading here before youi make a decision. Check out the 4 stroke section for information pertaining to your choice of engines. http://motorbicycling.com/forumdisplay.php?f=37
    Good luck.
  3. JRalstin
    JRalstin New Member
    Jul 26, 2012
    Thanks, yes im aware of purchasing the kit is much cheaper than buying the parts by parts. what i meant was, i got the engine, 5.5hp horizontal shaft (not sure what the brand was). i was wondering if there is a kit without the engine, is it quite possible. i did look up under the converation kit, none of them has complete kit without the engine itself. and by the way, thanks for the site.
    Joshua.
  4. bigbutterbean
    bigbutterbean New Member
    Jan 31, 2011
    2,417
    Tom, he wants to build a diy, but wants a list of parts. jralstin, a parts list will be difficult to provide without knowing exactly what engine you have. also, some parts may need to be fabricated. all parts are not always available for diy builds, because some parts that are available arent designed for the particular bicycle or engine you will be using. depending on how the motor is designed to mount, you may need a custom motor mount whiich you would need to make yourself or have made at a local shop. as far as a clutch, you need to know the diameter of the shaft that the clutch will go on. check go kart websites for the size clutch you need. you also have the option of installing a cvt (continuously variable transmission). other parts you will need will be a rear drive sprocket, a throttle grip and cable, an exhaust, a gas tank, a carburetor, fuel line. check the diy section for ideas and better explanations of what some of the parts are, such as the cvt.
  5. george_n_texas
    george_n_texas New Member
    Sep 4, 2009
    981
    If the output shaft is 5/8" then you could just buy a friction drive kit without the engine or a q-matic from azbill but check with him first to see if it will work. Most drive assemblies that use the engine type you have use a clutch assembly on a 5/8' drive shaft. www.staton-inc.com has em so does www.thatsdax.com the 4 stroke area mentioned before has lots of builds for you to look at to decide. Please feel free to ask questions along the way and welcome to the MB hobby!
    cvlt1 <<<<this is a friction drive
    I just remembered you do know these are illegal in NY state? Off road I think is ok tho.
  6. MotorBicycleRacing
    Jul 28, 2010
    5,690
    30
    There is no kit for what you want to build but AffordableGoKarts.com is
    where the custom 4 stroke bike builders get most of the needed parts.
    Does your motor have a 3/4" diameter shaft and how long?
    What kind of bicycle are you planning on using?
