mods
Discussion in 'Motorized Bicycle General Discussion' started by ct66rider, Feb 4, 2010.
  1. ct66rider
    ct66rider New Member
    Jan 20, 2010
    33
    what are some of the easyst mods that you can do just out of your shop to get these thing running faster?
  2. Tcams
    Tcams New Member
    Oct 18, 2009
    412
    Smaller Sprocket, Expansion chamber, Polish up the Intake manifold, and or get a billet intake from Pirate Cycles, CNS carb.
  3. ct66rider
    Jan 20, 2010
    33
    so far ive drilled holes in my stock exhaustcap and polished the intake up and tomarrow im gonna do the exhaust too
  4. Xiodinc
    Xiodinc New Member
    Oct 15, 2009
    171
    where do you drill the holes in the exhaust? like the end of the muffler?
  5. Randog707
    Randog707 New Member
    Oct 18, 2009
    177
    This what I did and I notice a big difference,First I cut out the stinger tube from the inside of my muffler,then I drilled (4) 3/16 holes in the muffler end cap,Next I ordered a 36 Tooth sprocket from Thats Dax, then proformance air filter from Sick bike parts,also intake manifold from manic machanic.I would just start off with a muffler mod,and maybe a better spark plug.
  6. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    I took off my muffler end cap,see the 3 holes,drill the 2 smaller holes larger,drill a extra hole if u want,put end cap back on. Drill a few extra holes in aircleaner plastic housing. That should be good to get you 30mph with a 44t sprocket.
    Next You could get a 36t.
  7. Xiodinc
    Xiodinc New Member
    Oct 15, 2009
    171
    does this muffler mod make it louder?
  8. tommyboy1442
    tommyboy1442 Member
    Nov 25, 2009
    239
    throw the stock ignition wire in the garbage and get a taylor or msd wire. defenitly rejet the carb, before you even put the thing together, take of the intake manifold and dremmel all the weld thats restricting your fuel, same for the exhaust, dremel out the engine side of exhaust smooth and do the hole drilling the guys are talkin about above here. alright guys, lets get technical, what can we really do to acheive an efficient burn and a strong runnin reliable engine?
  9. Bikeguy Joe
    Jan 8, 2008
    11,529
  10. Cabinfever1977
    Mar 23, 2009
    2,290
    Yes the muffler mod makes it louder but only at idle, at speed its about the same and takes off faster.
  11. PaulFlorida
    PaulFlorida New Member
    Dec 4, 2009
    52
    Take the head off, rub a marker on the gasket surface and deck it on a flat surface with 220 grit in a figure-eight pattern, and get a thin head gasket from SBP. This raises the compression, thus power. Plus, like everyone here has said, match the manifolds to the jug, using the gaskets as a template. Taking the muffler apart and removing the stupid welded baffles and drilling a few more 5/16" holes in the inner core, near the bottom end help a bunch. I hacksawed off 2" too, and that helped a little. Enjoy the new ride!
