Micargi Beach Cruiser Rover 7 Speed
Discussion in 'Motorized Bicycle General Discussion' started by jessejay356, Sep 8, 2010.
  1. jessejay356
    jessejay356 New Member
    Sep 8, 2010
    11
    I was thinking about getting one of these for my MB. How do you account for the twist shifter and the twist throttle? Any pictures would be of great help. Also, what is my best option with this bike to eliminate the rag joint?
    Thanks,
    Jesse
  2. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
  3. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    What I did with my grip shifter on the bars was simply move it over to the left side of the bars. Eventually, I also cut down the left side grip, so that I could still grip shift, instead of having to reach over the lip of the handlebar grip that came with the kit. It's easy, functional, and looks real nice.
    Eliminating the rag joint - apart from the aforementioned shift kit, there are a number of outlets that sell a variety of hub adapters for the rear sprocket. Pirate Cycles has a kind that clamps on the hub, there are others like that, too. Spookytooth has a kind that grabs the spokes, but it's all metal instead of rubber.
  4. jauguston
    jauguston New Member
    May 1, 2010
    142
    Put the grip shifter on the left side along with the clutch lever. Purchase a dual pull brake lever and put both brake cables in it and put the brake lever on the right side. The SBP shift kit is the ONLY way to go. Also SBP has a 7 speed chain ring for the rear that has a extra big first gear chain ring that is a great addition. A nice slow first gear and no peddling to start out. I found the supplied 36t front sprocket for the rear drive was too much for me. I changed to their 30t sprocket and go 30 mph in 6th gear at 5100 rpm. With the 36t I couldn't pull 6th gear on the flat with a Silver Grubee 66cc.
    With the stock single speed setup it took 7500 rpm to go 30 mph and a lot of pedaling to start out from a stop.
    Jim
  5. jessejay356
    Sep 8, 2010
    11
    Left side, DUH! It seems so simple, yet I didn't think of it! :) I'm not really looking for that much speed, so I think a shift kit is over kill for me. I don't mind doing some pedaling. I will definitely get a dual pull brake lever. I've look at spooky tooth, and sbc... but I'm not sure which adapters will fit the Micargi. I also am looking at which motor is the best, there are so many choices, and they all look the same to me. Have to keep looking.. Thanks for the help guys, I will be sure to post pictures of my build! :)
  6. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    Don't be afraid of the rag joint. With patience, it's perfectly serviceable.
    I also have a dual pull, and it's great. Yes, the motors are all pretty much the same, except for the 2010 Grubee redesign. You get a CNS carb with that, wider intake, and an interal CDI, as well as wider engine mounts.
