Marin build
Discussion in 'Motorized Mountain Bikes and Road Bikes' started by haste, Apr 23, 2012.
  1. haste
    haste New Member
    Aug 2, 2009
    131
    have a front suspension 98 marin hillhawk. Was going to turn it into an ebike..but I just love 2 strokes and I dont want dangerous batteries. This is also a hobby not a commuter...so tinkering is somewhat fun.
    The bike is okay...no dents but paint rubbing off some rust. So its not really worth selling..and needs a little work..one front spoke, rear wheel is bent, needs seat, tires.
    However it is chromo triple butted goodness...so no cracked frame! Has a POS RST fork as well.
    I will get a disc rear wheel with vbrake rim to use a sprocket adapter on rear..and convert the bicycle drivechain to Single Speed for simpliticy(who pedals these anyway?)
    Engine will recieve a blueprint, and overhaul. So 42 mph or so top end and decent 30-35 cruising.
  2. haste
    haste New Member
    Aug 2, 2009
    131
    was thinking about a shiftkit...but that adds to complexity. I cant imagine it adding any real power to a ported and tuned motor.
  3. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    You're right, shiftkits don't "add" power to any motor nor do they provide a higher top speed - in fact there's a very slight reduction in applied power due to fractional losses from the added friction.
    Provided the final gears are the same, you'd see a comparable top speed but with vastly improved acceleration as multiple gears allows you to have the best of both worlds, low for acceleration off the line & tall for cruise w/o redlining.
    As with most things it's all about application. If you're interested in raw top speed and don't care how long it takes to get there & don't have any hills to speak of - then a shiftkit isn't for you. If you live in hilly terrain and/or wish for far improved acceleration off the line and a good top speed... you may want to consider one - but they do add complexity & thus more maintenance, the added chain tensioning & wear can be a headache if you're a high mileage/abusive rider.
    What I've done is added a shiftkit to my comfy summer cruiser for my daily driving, commuting and light racing - but my winter beater is direct drive for simplicity, geared lower than it could be for max top speed, I pound the heck out of it w/o concern *shrug*
    #3 BarelyAWake, Apr 23, 2012
