Manic Mechanic Intake
Discussion in 'Motorized Bicycle General Discussion' started by Pitchfork311, Jun 24, 2009.
  1. Pitchfork311
    Pitchfork311 New Member
    Apr 29, 2009
    69
    With The Intake Jim makes work with his clutch actuator? I notice the lever arm is set to an angle, an am not sure if it will clear the carb using his strait through intake.
    Thanks Guysdrn2
  2. Pitchfork311
    Apr 29, 2009
    69
    Would Jim's copper exhaust gaskets be ideal as intake gaskets too?
  3. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    i believe the intake and exhaust gaskets are diffrent sizes.
    but maybe someone else knows for sure.
  4. Junster
    Junster New Member
    Jun 2, 2009
    445
    Ya he makes both parts. I'm sure they work together. He's way to good for them not to. I have his exhaust gasket but for the kind of seal you need at the intake I went to a auto parts store and bought a sheet of fairly thin gasket material. It's thicker than the stock gasket. It's pretty easy to make a new intake gasket. I did use a thin coat of permatex when I put it on.
  5. Creative Engineering
    Sep 20, 2008
    1,668
    Hello guys,
    Answers from top to bottom:
    Pitchfork311,
    Yes the intake works fine with both: my clutch actuator, and the factory unit.
    There is in fact a modification that needs to made...the clutch cable stanchion, (the piece that threads into the engine that holds the cable sheath), has to be shortened by 1/4"...otherwise the carb will hit the top of the stanchion.
    The dimensions for the exhaust and intake gaskets are different on most engines. I have had a few cutomers ask for custom intakes, as thier engines have the same stud spacing for the exhaust and intake.
    What's good for the exhaust isn't good for the intake as far as gaskets go. The dead soft copper is great for the exhaust, but it doesn't provide a flawless seal when cold...it expands with heat. The heat at the exhaust is what makes it work. The intake side doesn't get hot. There would be a vacuum leak. Typical automotive, fiber type, gasket material is better for the intake side.
    Cabin,
    You're right, they are different on most of the engines. From what customers have told me, there are a few that have the same stud spacing, exhaust and intake. I don't know which engines.
    Junster,
    Thanks! And yes you are absolutely right. The fiber sheet material from the auto parts store is far better than copper for the intake.
    Notes:
    I really didn't expect the intakes to sell very well because most engines are installed tilted to fit the frame.
    I have already made up some custom clutch cable stanchions to go with the Intake...Ask MB Monkey for pics, he got one with his Jag kit.
    I really wanted to O-ring the intake mounting face, so that a gasket would not be needed...there just isn't enough room. The studs are so close to the port.
    The final intake product will include the clutch cable stanchion and a quality die-cut intake gasket.
    Jim
