Magneto Gap
Discussion in 'Motorized Bicycle Trouble Shooting' started by TheMogollonMonster, Apr 13, 2018.
  1. TheMogollonMonster
    TheMogollonMonster New Member
    Mar 26, 2018
    Yep that's what I need. What is the proper magneto gap for a ChinaGirl and where exactly is it being measured from?
    Ran a search but didn't turn up anything. I swear this information was available before the page format change, but I can't seem to turn it up now.
    Anywho, as good as we all are at eyeballing, I'd like to have some numbers to work with now that I've got my Dax motor back (and a new carb, magneto, and CDI.)
  2. xseler
    xseler Well-Known Member
    Apr 14, 2013
    2,848
    79
    On every small engine I've worked on, an index card between the flywheel magnet and the coil/magneto is the gap I used. Always worked great. Don't know the actual gap.
  3. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,843
    104
    just before the 4 screws are tightened all the way, one wiggles the stator a bit to get it to sit firmly on the round, boss cast into the case
    the boss aligns it to have a clearance of about at least 8 thou at both top & bottom
  4. TheMogollonMonster
    Mar 26, 2018
    Thank you crassius, I can work with that. I ask because when I pulled the magneto cover off, I noticed a significantly larger gap on the bottom, nearly touching at the top.
