Lowering the Seat
Discussion in 'Motorized Bicycle General Discussion' started by Tcams, Mar 23, 2010.
  1. Tcams
    Tcams New Member
    Oct 18, 2009
    412
    I have an aluminum beach cruiser and I am wanting to lower the seat by cutting off 1/2" or 1" of the seat tube.
    Will doing this weaken the frame in any way??
    Im going for the bobber look so I want my seat as low as I can get it.
    Let me know
    Thanks
    tcams
    #1 Tcams, Mar 23, 2010
  2. azbill
    azbill Active Member
    May 18, 2008
    3,367
    looks like you could cut it at the slot, or a little below it, and be OK
    don't forget to cut a new slot, so you can tighten the seatpost again
  3. diceman2004
    diceman2004 New Member
    Aug 26, 2009
    568
    you will need to lower the clamping notch too , i think as long as you deburr all the edges nice and smooth , it should be good . the clamping notch looks like the only issue to me .
    if you use a hacksaw to do the notch , use a round file ( or a dremmel ) and make it a nice smooth rounded shape at the bottom again - like the original notch .
  4. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    17
    I cut the seat tube almost all they way to the top tube on the rockhopper tcams.
  5. city of angels
    city of angels New Member
    May 24, 2009
    470
    hey hows your bike going my trike is finally done and i will be posting pictures soon right now i am trying to get the turns right before i go in the road
  6. the new ausped
    the new ausped New Member
    Feb 10, 2010
    144
    if you want the seat AS LOW as you can here is a god idea on most bike seats there 2 pieces of metal coming out from he botom of the seatt take everyhing else off seat pole,tube and mechanise then bend them aa bit so the fo snugly n your frame and weld them on
  7. GoFastBicycles
    GoFastBicycles New Member
    Jul 29, 2008
    560
    Cut it flush with top frame tube weld( Tig. )seat post at the hight you want attach seat done.
    Adam
  8. diceman2004
    Aug 26, 2009
    568
    guys , he said ( aluminum frame )
  9. GoFastBicycles
    Jul 29, 2008
    560
    What ^^^^^^? Weld aluminum yes. Why not?
    Go see foureasy he can weld...... look for his ride in this months Horse mag you"ll see.
    Adam
    #9 GoFastBicycles, Mar 23, 2010
  10. wes
    wes New Member
    Aug 17, 2009
    207
    I cut the post down as far as i could on the rockhopper with a tubing cutter and then i cut the notch with a pair of good tin snips and it worked out great, good luck Tcams
