lovin it
Discussion in 'Motorized Bicycle General Discussion' started by Tim Mills, Jul 9, 2010.
  1. Tim Mills
    Tim Mills New Member
    Oct 9, 2009
    66
    hello all my fellow MBers i have had my bike for about a week now and im lovin it. Just got my carb adjusted, ordered my ngk spark plug hope it makes a little difference its doing really well so far. I took my tank off tonight to clean it the stock filter was almost full of crud i just installed in line filter. I do have a question I seem to have a leak around my spark plug what can i do about this. any input would be great thanks
  2. DOC BOLM
    DOC BOLM New Member
    Aug 21, 2008
    681
    Tim is their a copper gasket under the plug.
  3. Tim Mills
    Oct 9, 2009
    66
    Doc cant believe your up, cant believe im up lol anyways there is the little ring gasket and i have tried a different spark plug , same thing
  4. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    Seat may not be smoothe,or threaded off center,,observe the plug gasket for iregular shapes
  5. DOC BOLM
    DOC BOLM New Member
    Aug 21, 2008
    681
    Your head may not be drilled right.Someone out their must have had the same thing.Help.
  6. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    Could you use two plug gasket rings
  7. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,646
    65
    Are you sure it is tightened down and the head bolts are tight? I ask just because I have not run into a leaking plug before but did have a head bolt make one look like the plug was the culprit.
    More asking here, but if it is the plug, anti seize? Is like a thread sealer but is to keep threads from bonding. They make special stuff for plugs, but I have never tried it. Some one will know and better advise you. I googled it and came up with some interesting reads. spark plug thread anti seize - Google Search As a way of help seal them)
    Great to hear your enjoying your MB so much. These things are great.
    #7 Dan, Jul 9, 2010
  8. Tim Mills
    Oct 9, 2009
    66
    thanks for all the help guys im going to make sure the head bolts are tight and then see about the plug hopefully its no big deal
  9. Tim Mills
    Oct 9, 2009
    66
    Again thanks for all the help guys,check the head bolts this morning one was really loose right where the oil was coming from. Glad i got a place to go to for help you guys are great. Did i mention im having so much fun usflg
