Long Time Lurker
Discussion in 'Introduce Yourself' started by B.C Rider, Dec 17, 2009.
  1. B.C Rider
    B.C Rider New Member
    Dec 17, 2009
    21
    Greetings from the Wet Coast.
    Going to have a few questions.....................
  2. Ilikeabikea
    Ilikeabikea Moderator
    Staff Member
    Jan 27, 2008
    2,323
    Welcome, glad you're not lurking anymore.................
  3. Motor Boys
    Motor Boys New Member
    Nov 6, 2009
    179
    Welcome and ask away.
  4. B.C Rider
    Dec 17, 2009
    21
    Is this considered normal?
    To have this oil around.
  5. rkorson4209
    rkorson4209 New Member
    Oct 10, 2009
    251
    No I think you might have a leak. Check your head bolts to see if they are tightened, if they are then you might want to check your gaskets, and use gasket sealer.
  6. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,825
    12
    Welcome to the forum.
    I had some premix puddling around the spark plug until I installed an NGK spark plug.
    The original plug did not fit as precisely.
  7. Ghost0
    Ghost0 New Member
    Mar 7, 2008
    764
    From what little I can see of your exhaust header it appears that is where the oil is coming from. Best bet is to clean everything well with brake clean and pay close attention to where the oil is coming from. It does not look like it is coming from your head gasket or plug. I would pull the exhaust pipe and replace the gasket and use some RTV to seal it up.
  8. B.C Rider
    Dec 17, 2009
    21
    Thanks for the come back guys.
    Here is a better pic.
    I have over 300k on it now.
    Seems to bog a little on hills.
    Just hums along the flats though.
    Got this through Chris Hill.
    I hope its not over tightened.
    Never touch a bolt on it ever.
  9. rkorson4209
    Oct 10, 2009
    251
    That is what mine did when the head leaked. You say you never tightened it down. I think you should torque em down, and like i said check your gaskets. When you get these motors new they are not tightened, I assumed they were myself
  10. Ghost0
    Ghost0 New Member
    Mar 7, 2008
    764
    After seeing the updated photo I am going to say it is the plug leaking.
  11. rkorson4209
    Oct 10, 2009
    251
    even though he said he never tightened it down
  12. Ghost0
    Ghost0 New Member
    Mar 7, 2008
    764
    If it is a Chris Hill motor I don't think retorquing the head would be necessary but can't hurt after heat cycling. Besides if the head gasket is leaking I don't see how it could end up on top of the head and not be apparent anywhere on the cylinder.
  13. B.C Rider
    Dec 17, 2009
    21
    The 2 fronts were loose.
    About 7lbs.
    Thanks again.
  14. Ghost0
    Ghost0 New Member
    Mar 7, 2008
    764
    I've been wrong before and I am sure it will happen again. Hope that solves the problem.
  15. rkorson4209
    Oct 10, 2009
    251
    That is true i didn't think about that one. my bad. I don't know of chris hill
