line filter question
Discussion in 'Motorized Bicycle General Discussion' started by mrmpg91, Apr 11, 2011.
  1. mrmpg91
    mrmpg91 New Member
    Mar 12, 2011
    hello, i was wondering were in the gas line would be the best place to place the filter, if it matters. and also which direction to place the filter.
  2. Pilotgeek
    Pilotgeek New Member
    Apr 6, 2011
    403
    I would say wherever in the line it works best for mounting. It should have a little arrow on the filter for fuel direction, and if not, the flatter side that looks like a cap goes towards the carb. Also, I recommend using a high-quality filter. I used a snowmobile in-line filter.
  3. DaveC
    DaveC Member
    Jul 14, 2010
    970
    If it's the flat disk kind it really doesn't matter, if there's an arrow then follow directions. If you have a paper element and if there's no arrow the fuel should flow from the outside of the element to the inside. This gives maximum area for sediments to fall out and be caught in the bottom of the filter without clogging the filter.
    With a inline filter don't use the intank one on the valve, very low quality, very small surface area and redundant with an inline filter.
    The copper tank I'm building is getting a glass sediment filter ment for a Massey-Fergeson tractor :)
  4. Black_Moons
    Black_Moons New Member
    Oct 25, 2010
    207
    I love the sintered bronze filters. Mainly because they are strong enough that I can take em out and blow em out with an air hose. (Might not get the fine stuff out, but sure gets the larger debrie out)
  5. 2door
    2door Moderator
    Staff Member
    16,310
    And don't make the mistake that a few have done: The arrow doesn't mean "up". It indicates the direction of flow.
    I prefer the clear type so you can see how much sediment is in the filter. Any place that sells lawn mower, motorcycle or small engine parts can supply you with a good quality in-line fuel filter.
