lifan motor
Discussion in 'Motorized Bicycle General Discussion' started by Elixys, Dec 2, 2010.
  1. Elixys
    Elixys New Member
    Sep 14, 2010
    127
    saw a good deal on a lifan motor 150cc and wanted to know if anyone had tried to put that big a motor on a bicycle? im sure it can be done and if bidding goes well Ill have the motor in about 3 weeks.....im just worried about how fast im going to kill myself on the thing once i get it installed.....but best not to count the chickens before they hatch i suppose. still got to obtain the motor.....may have to build a custom frame for it..wee......i picture something like that happening and then this.bf. or this.duh.
  2. The 26incher
    The 26incher New Member
    Dec 19, 2009
    395
    I put a 150cc honda clone engine in one of my minitrails and it does 75mph! Are you talking about one of the 4 or single speed engines?
  3. hurricane
    hurricane New Member
    Sep 20, 2010
    75
    wow 150 cc on a bike frame ? please have some one video tape this accident waiting to happen. I will get my popcorn.
  4. civlized
    civlized New Member
    Apr 28, 2009
    690
    That is gonna be fun! Don't forget the bigaz brakes. Not sure about your bike, but using an engine like this is what some of us prefer. Mine is only a 50cc and does over 50mph, so be careful.
  5. silverbear
    silverbear The Boy Who Never Grew Up
    Jul 9, 2009
    8,188
    10
    Boy, you've got that all tricked out... sweet bike!
    SB
  6. civlized
    civlized New Member
    Apr 28, 2009
    690
    Thanks, SB!
  7. hurricane
    Sep 20, 2010
    75
    Holy carp Cival,did you build that one yourself ? If so much kudo's that is one perfectly fit motor to bike frame match Ive seen in along time.
    Hope you dont mind but I kept this picture for future inspiration.
  8. civlized
    civlized New Member
    Apr 28, 2009
    690
    Thanks, hurricane! Yep, I did all of that one. That is my pride and joy. Thanks for the compliments, and of course you can keep a pic.
    http://motorbicycling.com/f40/atv-50cc-full-auto-stretch-13417.html
    Here's a link to the build thread, if you're interested.
  9. hurricane
    Sep 20, 2010
    75
    thx for the link, but 13 pages long will have to wait to read it so I saved the link.
  10. civlized
    civlized New Member
    Apr 28, 2009
    690
    Yeah, it is kind of long. There are several pictures of the finished product on page 8, if you want a better look without reading all of it.
  11. Elixys
    Elixys New Member
    Sep 14, 2010
    127
    hrmmmm......i think it can be done so im going to attempt it......ill need a different type of bike frame though......need a frame with 13in. wide/16in tall/15in long/ in frame clearance. anyone know where i can get a frame like that? im sure they make them......
  12. Elixys
    Elixys New Member
    Sep 14, 2010
    127
    heres the specs,
    150cc LIFAN High Performance Engine, Black Chrome, 4 stroke, 5 speed manual, air-cooled, electric start/kick start, single-cylinder, CDI ignition.
    SPECIFICATIONS
    Exterior Finish: Black Chrome
    Type: single cylinder, 4-stroke air-cooled
    Bore x Stroke: 61mm x 49.5mm
    Displacement: 144.7ml
    Compression ratio: 9.2 to 1
    Max. HP: 12.0 HP @ 9,500 rpm
    Idle: 1,500 RPM
    Oil capacity: 8L (10w-30)
    Start Mode: electric/kick
    Weight: 64 pounds
    Clutch: Manual
    Gears: 5 speed, Constant Mesh
    Ratios: 2.769/1.882/1.400/1.130/0.960
    Magneto: Permanent magnetic
    Voltage: 12 Volt
  13. The 26incher
    Dec 19, 2009
    395
    Oh, so it the XR200 clone not the CT70 engine. If you are going that route, get the 200cc or the 250cc. Same size on the outside, just bigger in the inner...
  14. Elixys
    Elixys New Member
    Sep 14, 2010
    127
    well first things first i need to get a frame that i can mount it into....
    any ideas as to maybe a stretch cruiser frame or you think im going to have to do some mods to a couple of the frames i have around
    #14 Elixys, Dec 3, 2010
  15. NunyaBidness
    NunyaBidness Active Member
    Jun 29, 2008
    1,062
    With that much power I would not mount that in a standard bicycle frame. I would build a custom bicycle frame specifically for that motor. Hydraulic disc brakes front and back and if it has to be a rigid frame at least get a front shock. It would be better as a full suspension build, in my own humble opinion of course.
    How ever you decide to do it I will be following this build now.
  16. WildAlaskan
    WildAlaskan New Member
    Sep 30, 2010
    581
    i agree a bicycle with this kinda power deserves a custom built frame up to specs made the same amount of material of a steel frame but built with chromoly instead for added strength and rigidness
    if you wanna go all out use push though axles for strength double walled heavy duty wheels and hydraulic disk brakes front and rear with emergancy v brakes set up to a dual brake lever with a lock button to act as parking brake
    then after all that you can work on a lighting system to make your ride street legal turn signal brake light tail light hi/lo beam headlights and a horn
  17. Allen_Wrench
    Feb 6, 2010
    2,787
    Yeah. What he said. Really good brakes. There will quickly come a time when you want to stop fast way much more than you want go fast.
  18. NunyaBidness
    Jun 29, 2008
    1,062
    You ain't just whistlin' dixie either. Seems like there are a lot of people out there that think simply because you are on a bike that you have no right to expect to be a part of "on coming traffic", if they want to turn and you are coming they will go ahead and turn in spite of you being "on coming traffic".
  19. WildAlaskan
    Sep 30, 2010
    581
    i deal with this every time i go out on the road i try to stay next to cars on the road and use them a s a barrier against oncoming traffic trying to turn
    alot of drivers turn despite seeing us us i think its cause they just dont expect us to be going so fast
    another thing that scares me is when a car pulls up to the road and wants to turn right (same way im going) and starts to pull out and has to brake cause they suddenly realize we will collide or even worse when they dont give a **** and just go ahead and pull out anyway
    in my experiences of avoiding car vs bicycle accidents it is almost always the drivers lack of attention or judgment that has put me in jeopardy i really cant think of one incedant that was my fault but i can think of several times i have had to avoid being run over from retard drivers
    for sure if you wanna be safe stoping power is a must our lives depend on them but having good brakes is only part of the equation i wear a safety vest and have lights on my bike so there is no excuse to not being seen
  20. Elixys
    Elixys New Member
    Sep 14, 2010
    127
    well first things first, i still have two days until the sale closes on the motor. if I dont get out bid, then i should have the motor in after about 2 weeks max. i sent a pm to sportscarpat and axed him how much it would cost me to get a customized drop loop bike frame and gas tank for it. if the price is right, ill use that as my frame for this bike. :)....oooh if i get it going this is going to be one heck of a build......ill have to get a digital camera so i can start posting some pics......but im getting ahead of myself. still have to get that motor.
