Lets talk head lights
Discussion in 'Motorized Bicycle Accessories' started by Flyman, Dec 15, 2014.
  1. Flyman
    Flyman New Member
    Nov 28, 2014
    258
    What do you guy recommend for a bike head light.Do they run
    off a battery pack & if so for how long.I,m new to all this & counting
    on you folks help.
    Fly .trk
  2. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    This is what I use, these are super bright and the 8.4volt rechargeable battery pack last for a good while, they have low beam, high beam and strobe flash.
    Only thing I have found that using the strong L.E.D. lights due that is a slight pain is that my digital speedometer are rendered useless as long as the light is on, maybe I just have them to close together, but there is some kind of interference that the light puts off that wacks out the wireless or wired digital speedos I have, other than that they are excellent and will really light things up, best bang for the buck in lights I have found and you can get higher MAh batteries fairly cheap, here is one that is twice the capacity almost as the standard 6400mah battery, the claim is that the headlight will last 4-6 hours with this 12,000 mah battery.
    http://www.ebay.com/itm/18650-Recha...US_Rechargeable_Batteries&hash=item258744f848
    I dont have one yet but I also plan to get the red taillight version that uses the same batteries. here are a couple links to what I'm talking about.
    http://www.ebay.com/itm/Zoomable-16...510?pt=LH_DefaultDomain_0&hash=item462e230ffe
    http://www.ebay.com/itm/MagicShine-...=100012&prg=11353&rk=1&rkt=10&sd=281067506059
    Hope this helps out a bit Flyman
    Oh by the way the headlight comes with a method to mount on bike bars or it can just be worn as a head lamp so when you turn your head you will always have light where you're looking, I kinda like using them that way at times, battery will strap onto belt loop and its an easy set up that I can use no matter which bike a decide to ride since I have four of them.
    Map
    #2 mapbike, Dec 15, 2014
  3. mapbike
    Mar 14, 2010
    5,380
  4. Flyman
    Flyman New Member
    Nov 28, 2014
    258
    Man 4 to 6 hours is longer than I thought would be available.
    I thank you guys Fly
  5. mapbike
    Mar 14, 2010
    5,380
    You're very welcome, I think a standard 6400mah battery pk will run around an hour on bright and maybe close to 2 hours on low beam, I haven't actually ever tested it to see for sure but I havent ever had it run down on me either and that was on a 40-45 minute night ride on high beam the entire time.
    map
  6. bluegoatwoods
    bluegoatwoods New Member
    Jul 29, 2012
    1,577
    I use these.
    http://www.amazon.com/gp/product/B00C2MHNJK/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    They're plenty bright.
    I use two of them. Not so much for the light. One gives plenty. But I run two in case one of them ever goes bad by surprise.
    I've never used up the battery. I have a feeling I can get 6 hours or so on low setting.
    My only complaint is that the mount is a bit squirrely. But it wasn't hard to fasten a different mount.
  7. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
  8. SuperDave
    SuperDave New Member
    Sep 24, 2011
    179
    [​IMG]
    I took a standard bicycle bullet light & modded it myself with 5mm blue/white LEDs from LED Warehouse (.com). Now they are very bright, from my driveway to the corner(1/4 mile away) it will luminess the reflective material on the stop sign, and I'm told that I am easy to see even during daylight on a sunny, cloudless day.
  9. Tyler6357
    Tyler6357 Member
    Mar 15, 2012
    790
    10
    I don't ride at night that often so I got two of these headlights. They are very bright and with 2 of them they light up the road very well. You can adjust the narrowness of the beam and they run on 3 AAA batteries. What I like about them is that the mounts fit all the way around the lights so my china girl won't vibrate them loose. Also, it's handy to be able to easily remove one of them to use as a flashlight on the side of the road at night if needed. These are pretty cheap and does not fit if you are going for a more classic bicycle look.
  10. HDCowboy
    HDCowboy Member
    Jan 3, 2015
    44
    I'm a newbie here and still haven't even completed my first build yet, but if my memory serves me correctly the ChinaGirl engines have an extra 6 volt wire coming from them that is unused and which should allow you to use one of any kind 6 volt light of your choice (depending on wattage ect). I dont know if they make 6 volt LED lights but one of the old 6 volt generator set up lights like these ought to be able to be direct wired to the motor if you so choose.........
    [​IMG]
    #10 HDCowboy, Jan 30, 2015
  11. Flyman
    Flyman New Member
    Nov 28, 2014
    258
    Funny I started this thread when I was building me first bike a few months
    back. So ya, I,m still a newbie so to speak. But I do know this, there only
    one bike light & then there is the rest.
    Cree makes the best light out there money wise or brightness. When I first came
    into this hobby I had Cree flash lights & they are unbeatable. I had no idea
    they made bicycle lights.
    My Son rides mountain bikes in Tucson at night in the desert. Every one of
    there group has Cree lights on there bikes. If you want to see were you are going by a Cree. https://www.youtube.com/watch?v=aGKnw3bUSx0 https://www.youtube.com/watch?v=mBRU5RUf-jI The one thing China did right.
    Fly JMOHOP PS $20 prime Amazon, can't be beat!
    #11 Flyman, Jan 30, 2015
  12. Rudz
    Rudz New Member
    Jun 24, 2014
    454
    I have two cree 6x T6 XML lights, 12 leds total and two 9600 mah 8.4v 18650 battery packs on my bars, a cree solar storm light on my helmet with a 6400 mah 8.4v 18650 pack on my helmet.
  13. Flyman
    Flyman New Member
    Nov 28, 2014
    258
    Dang you can sure see where your going & they can see you coming no doubt
    about that.
    That's cool! Fly
  14. Rudz
    Rudz New Member
    Jun 24, 2014
    454
    Definitely, dark desert roads get lit up.
  15. mapbike
    Mar 14, 2010
    5,380
    a person should always have very bright lights for night riding in my opinion, the tail light should be extremely bright if possible also, some of the dinky little tail lights wont cut it, but the larger ones that flash are good because I sure dont want to get run over from behind by someone who couldnt see my light.
    I like a bright long distance head light because a moyor bike move so much faster, those big pot holes or something in the road can be under the front rire before you know it if you cant see at least 40-50 yds out ahead.
    only problem I have had eith the 1600-1800LM lights Ive bought is that the LED lights screw up my digital speedo when the lights are on,they jack with the wired and the wireless ones Ive used, I wish I knew of a good way to shield them from that interferene.
  16. Flyman
    Flyman New Member
    Nov 28, 2014
    258
    (only problem I have had eith the 1600-1800LM lights Ive bought is that the LED lights screw up my digital speedo when the lights are on,they jack with the wired and the wireless ones Ive used, I wish I knew of a good way to shield them from that interferene. )
    Hummmmmmmmmmmm I have not tried mine yet with the speedo. Interesting, there
    must be something that can be done. Tell you what Map next time I make it to OKC, I
    will drop by the company I worked for before retirement. Our R&D dept has some really
    slick sparkys designing the electronics on the stuff we made. I,m sure one of those
    guy's will know a fix.
    Fly
  17. mapbike
    Mar 14, 2010
    5,380
    sounds good Fly, a way to sheild the speedo or something to put around light to stop whatever its sending out would be excellent.
  18. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
  19. mapbike
    Mar 14, 2010
    5,380
  20. Rudz
    Rudz New Member
    Jun 24, 2014
    454
    Judging by the pictures it looks like a small concentrated beam
