leaky fuel cap
Discussion in 'Motorized Bicycle General Discussion' started by biker G, May 6, 2010.
  1. biker G
    biker G New Member
    May 6, 2010
    6
    my starfire fuel cap leaks.
    I fixed it by sealing the joint underneath where the two parts of the cap are crimped together along with the small vent hole under the lip.(I used solder but epoxy should also work)
    next drill a similar sized hole in the center on the top side.
    Mine no longer leaks even when full.
  2. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    14
    Welcome to the forum. Thanks for sharing Biker G, very useful info (^)
  3. Drewd
    Drewd New Member
    Jul 25, 2008
    425
    please post pic of where you drilled new hole, I didn't undestand what you mean. thanks!
  4. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    He drilled new hole on the top center of the cap.
  5. city of angels
    city of angels New Member
    May 24, 2009
    470
    pics please i would like to see ir since mine keeps leaaking like crazy
  6. biker G
    biker G New Member
    May 6, 2010
    6
    Sorry about no photos guys but I cant find my camera just now but I will try later.
    In the mean time though cabinfever1977 guessed right about the placement of the new vent,on the top center of the chrome side.
    As for the sealing part of the operation, you will notice that the seam where the top chrome piece and the inner gold half come together is not perfect.
    Seal this with something impervious to gas along with the single small hole up under the lip.(NOT the holes down by the locking mechanism.)
    I hope this helps because those fuel caps are unacceptable as is.
    Good luck!
  7. Cabinfever1977
    Mar 23, 2009
    2,290
    Actually if you don't fill your tank more than half way, it shouldnt leak, much.
    I put around 35 cents worth of gas in my tank and toss in around a 1oz of oil and shake bike.
    One could either replace the tank with a better one or add a threaded neck from a metal can with screw cap and add a pin hole in middle of cap for air.
    #7 Cabinfever1977, May 9, 2010
