killed another
Discussion in 'Motorized Bicycle General Discussion' started by turnofftheradio, Sep 2, 2014.
  1. turnofftheradio
    Sep 4, 2012
    242
    [​IMG]
    [​IMG]
    Not sure if ring broke first or pin clip, but no saving it anyways. Grrrr
    The sthil bearing is still just fine, about 1k miles on this one
    #1 turnofftheradio, Sep 2, 2014
  2. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,641
    62
    Dang. Not good
  3. onellesen
    onellesen New Member
    Aug 27, 2014
    17
    Sorry to see that. Did you have any mods done, Porting? high compression?
  4. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,660
    70
    you'll probably enjoy these more if you don't break them
  5. turnofftheradio
    Sep 4, 2012
    242
    No mods other than the sthil bearing which is still in perfect condition after all this, and a slightly thicker base gasket, so probably less compression than normal. I was going around 35 when it set loose. It was kind of scary. Locked up the back wheel on me. I was surprised to find the transfer completely gone when I got it apart. The big bummer is that I broke my head trying to get it off. For some reason it was really bound up on the studs. The engine itself was one of the bad batches of bgf from a while back. I thought I addressed its weak points. I guess not ;). Meanwhile I have an extra jug and piston, just no circlips and no head now. Won't be to expensive to get rolling again me thinks. I was going to ditch the angle fire anyways sooner or later. I'm considering a balanced crank while I'm in there though, just finding it hard to justify with the failures I've had with it.
    In anger I threw a hammer at the jug. Those fins are not very strong are they? :)
  6. turnofftheradio
    Sep 4, 2012
    242
  7. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,641
    62
    Some times ya just gotta beat em to death with a sledge or just throw a hammer. Just part of the hobby. (and feels so good!)((at the time))
  8. onellesen
    Aug 27, 2014
    17
    Well Goodluck getting going again, Where are you getting the balanced crank from?
  9. turnofftheradio
    Sep 4, 2012
    242
    As far as I know Dax and motorbicycleracing are the only two who offer such a thing. I'm so cheap I may just try it myself though. I do wish I knew what caused the failure but i guess its a moot point, since the is no better ring or circlip available that I am aware of. At least I got over triple the miles this time over the last tear down. The "better" bearings all held up well.
    I should also mention that I am terrible to my engine. I run it wot 90% of the time and rarely go slower than 30, so I ask a motorized bike to be a moped, fully aware that it is not. I have been running lucas 40:1, then redline 40:1 for every mile of it. 1k isn't tragic miles to me for a break down. 300 really ticked me off last time though. Idealy I would still like to see 3k before this kind of failure, then I may not throw hammers at it.
    I'll be back on the road in time to enjoy fall riding.
  10. turnofftheradio
    Sep 4, 2012
    242
    Its unlike me to do such a thing. But it did feel pretty good, and I had good aim thankfully.
    where is the hammer throw emoticon? :)
  11. allen standley
    Oct 22, 2011
    796
    20
    Very same thing happened to my engine, I assumed the clip somehow popped off. Very similar looking damage to what you have right there. Oh Well! - I ride 15 mi daily to and from work. Same bike on my 4th engine in as many years. I do well to get 3000 mi before a catastrophic failure. I don't abuse my bike-I try to find the happy rpm where it likes to run and keep it there. Nonetheless, I bought my replacement from DAX (balanced) runs very smooth, just feels like a real creamy happy motor. Gonna call him this afternoon and get one of those Puch looking compression heads. Good Luck! Amsoil interceptor mixed 32:1 1/2 oz K-100 anti ethanol per gallon.
  12. crassius
    Sep 30, 2012
    3,660
    70
    I have two customers that go thru about 3 motors a year - they feel that riding WOT is enough fun to justify the expense (which is really small after the amount they save on gas).
  13. turnofftheradio
    Sep 4, 2012
    242
    I guess I'm lucky to have winter here, or I'd kill more.
    Really though my piston and jug looked awesome after 1k, lots of life left if the clip had not set itself free. First death was crappy bearings.
  14. YesImLDS
    YesImLDS Member
    Jun 29, 2013
    954
    Same thing happened to my motor recently, just not as catastrophic! Retaining pin popped after a bearing replacement (around 200 miles after) Jammed between the piston and the cylinder and destroyed the transfer port as well as the piston/rings. Crazy how something the size of half a paperclip can cause so much damage!
  15. crassius
    Sep 30, 2012
    3,660
    70
    part of the reason I don't rebuild motors - other part is it's just too cheap to put in a new one
  16. turnofftheradio
    Sep 4, 2012
    242
    [​IMG]
    Got worse as I was cleaning it up. Found what appears to be a crack in my frame. I have to grind a little to make sure, but it sure looks cracked. I'm sad
  17. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,641
    62
    Dang TOTR, rough week.
    Just gotta keep swinging, Buddy. Gets better.
  18. turnofftheradio
    Sep 4, 2012
    242
    I have a few frames around. I'll probably use the Schwinn cruiser frame, but I have a couple of surburbans that are strong candidates, but 27".
    I just liked that frame a lot. fit the engine just right, and carries my moped registration that I will have to fight to get on another frame. I'm not sure if my heart is going to be in it for a while.
  19. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,641
    62
    Not a thing wrong with taking a break. Not fun if it is all frustration.
    I take a few every couple of yrs. When I ride again, brings back the joy.
  20. allen standley
    Oct 22, 2011
    796
    20
    That an Aluminum Bike?
