1. WarriorAirman
    WarriorAirman New Member
    Aug 5, 2013
    11
    i want to put some kind of key on my bike to deter crooks from trying to steal my bike i was looking at maybe wiring it in lue of the kill switch. i was wonering if anyone had experience with this and might be able to help me.
  2. MotorBicycleRacing
    MotorBicycleRacing Active Member
    Jul 28, 2010
    5,684
    24
    Just install a hidden kill switch so a crook will have no idea why it isn't starting.
    You can have the throttle kill switch and a hidden one.
    Hopefully your bike is hard to pedal so they can't get away! :D
  3. LR Jerry
    LR Jerry Active Member
    Dec 19, 2011
    1,027
    Staton Inc sells keyed kill switches.
  4. RicksRides
    RicksRides New Member
    Feb 22, 2012
    864
    I use ones from small 2 stroke snothrowers
  5. Len455
    Len455 New Member
    Mar 11, 2012
    144
    If its a 2 stroke the you can put it inline with the positive magneto wire. If its a four stroke its a tad bit more complicated. I had a thread on it a while back. You need to wire up the kill switch with a relay so that when the key is out the relay is closed and completing the kill circuit and when it is turned on it opens the circuit. I used a 12 volt car relay with a 9 volt battery. Never had to replace the battery in about 7 months maybe more. I have a wiring diagram for the four stroke if needed.
  6. curtisfox
    curtisfox Well-Known Member
    Dec 29, 2008
    4,010
    31
    How about poasting the diagram for 4 stroke that would be awesome............Curt
  7. RicksRides
    Feb 22, 2012
    864
    For a 4 stroke just run a ground wire to a kill switch and the other side of the switch to the top of the plug
