Junk Kit Parts
Discussion in 'Motorized Bicycle General Discussion' started by Retmachinist, Apr 23, 2010.
  1. Retmachinist
    Retmachinist New Member
    Oct 21, 2008
    637
    After fixing my fourth gas cap, I am trying to decide what is the worst junk part that comes with these kits. Seems the little locking tab in the gas cap always wants to fall inside the cap.
    I don't know what is worse, the gas cap, the chain tensioner or the rag joint? I never use the chain tensioner or the rag joint, I machine my own.
    John
  2. TerrontheSnake
    TerrontheSnake New Member
    Jun 1, 2009
    720
    I can give votes for the gas cap, and tensioner !CRAP!, my rag joint is still alright. You should have seen how bent the first sprocket I was sent was though. LoL of all the things really?!
  3. macattie88
    macattie88 New Member
    Dec 2, 2009
    102
    i would say the rag joint(replaced quickly with jims adapter)...have had no problems with anything else
  4. freewheeling frank
    freewheeling frank New Member
    Mar 10, 2009
    440
    chain tensioner! i build em so i dont have to use em.frank
  5. Nashville Kat
    Nashville Kat Active Member
    Apr 20, 2009
    1,442
    6
    Put some cut nylon circles from a sherbet lid under the gasket on the cap- stops it leaking- never had any other problem-
    also gasket sealer on nuts and idle screw on carb stopped leaking there too.
  6. tyrslider
    tyrslider New Member
    Sep 26, 2008
    958
    Don't forget the gas tanks, petcocks, throttles, grips, chain etc; pretty much everything in the china girl kit's are crap. And amazingly they, for the most part, go pretty good!
    If I do any more 2 smoke stuff for anyone I'll just buy the motor and cdi and source/make everything else myself!
    None of it is confidence inspiring.
    In spite of that fact it amazes me to no end that people put these on bikes I wouldn't ride w/o a motor, let alone w/, and get pretty decent reliability out of 'em!
  7. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    The only thing i had a problem with is the gas cap, the tab fell inside the cap and i had to cut the cap in half to get it out then put the cap back together and put the tab back on. Also the cap is hard to find or i would have bought a cap at a local store.
    And no i didnt want to order one with high shipping cost or pay $20 for one either.
    They should have used a regular cheap lawnmower screw on cap which is available at all hardware stores and also at lowes and stuff.
    The rest of the kit can be adjusted or replaced with basic brackets, ecept the carb which also has very weak tabs and tend to break easy.
    The throttle can be replaced with a brake lever.
  8. 2door
    2door Moderator
    Staff Member
    16,308
    30
    The kit supplied fuel line.
  9. Bikeguy Joe
    Jan 8, 2008
    11,529
    I second the fuel line thing, it's un-usable.
  10. Maxvision
    Maxvision New Member
    Jun 13, 2009
    551
    Unusable because it's too thin and won't fit over the nipples? If so, a good hot hair dryer or heat gun will soften the vinyl tube enough that it will stretch over the nipples no problem. No hair dryer or heat gun? A lighter or candle will work too, just don't get it so hot it catchs fire...lol
  11. Pablo
    Pablo Master Bike Builder & Forum Sponsor
    Dec 28, 2007
    3,658
    We have a winner.
    The way they break is fairly unremarkable, the frequency high, and the timing amazing.
    In fact, combined with the leaking lousy gas cap the name should be changed from petcock to flamingwiener.
  12. Humsuckler
    Humsuckler New Member
    Jul 28, 2009
    458
    lawl @ Pablo.
    i vote for the little fuel line pretzel that comes in one of the 3 boxes.... lol
  13. flybytaco
    flybytaco Metal Molding Madman
    Oct 17, 2009
    1,176
    Its funny you mention gas caps sucking lol watch this video at the end where i rev it watch the gas cap lmao
    YouTube - 941_0517.MOV
  14. Ulysys
    Ulysys New Member
    Apr 25, 2009
    60
    In my kit, the worst part was easily the rag joint. The rubber discs were cut so badly that is was impossible to get the sprocket centered at the same time it was flat, and tight enough to actually hold that way. So I rode the thing forever with a badly centered sprocket and just lived with the lurching under speed. When I went to put the motor on a different bike, I found a local guy that had extra rag joints from Grubee kits, and I bought some longer bolts. With all that, I was actually able to get the sprocket centered and as level as possible (the sprocket is a little warped), and now there's no more lurching. Needless to say, my next kit will be a Grubee :).
  15. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    I didn't seem to get an auto release gas cap with mine,I must have an inferior kit,lol
  16. Pablo
    Dec 28, 2007
    3,658
    Chet's nuts roasting over an open fire.......
    (That vid was hilarious - I love the hand over the tank opening)
  17. Cabinfever1977
    Mar 23, 2009
    2,290
    My petcock and fuel line worked fine, The number one easy to break part is the Gascap.
  18. TerrontheSnake
    Jun 1, 2009
    720
    I vote Pablo for president!!
