Is this a problem?
Discussion in 'Motorized Bicycle General Discussion' started by Mind_Reader7, Sep 9, 2010.
  1. Mind_Reader7
    Mind_Reader7 New Member
    May 1, 2010
    393
    I've noticed recently that my bike will idle alright from a cold start, but after heating up, at idle it will die in 1-2 seconds. Is this a problem?
  2. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    Depends on what motor you're talking about. 2-cycle - are you turning the choke off after starting? Make sure the nut under the air cleaner that holds the choke cover in place isn't loose, and allowing the choke to fall closed regardless of what you've done with the choke lever.
  3. Mind_Reader7
    May 1, 2010
    393
    I don't use the choke. Yes, it's a 2 stroke.
  4. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    I would remove the air cleaner and check to make sure that choke cover is attached properly and tightly. Squeeze the fuel out of the filter element while you're at it.
