Is there an aftermarket manual cluch kit?
Discussion in 'Motorized Bicycle General Discussion' started by illMATTic, Dec 15, 2012.
  1. illMATTic
    illMATTic New Member
    Oct 5, 2012
    27
    I there such a thing as a manual clutch kit I can work with a hand lever? I want something to work likea regular motorcycle. I am using a side shaft engine.
    Thanks
  2. bigbutterbean
    bigbutterbean New Member
    Jan 31, 2011
    2,417
    If you have the option of using a centrifugal clutch (I'm assuming you plan on installing a non-kit 4 stroke engine on your bike), then why not go with that? One less lever you need on your handlebars.
  3. bigbutterbean
    Jan 31, 2011
    2,417
    Oh and there is no manual clutch "kit" that I know of. There might be some designed for motorcycles that will work, I would suggest checking with a motorcycle shop for that. But none of the transmissions currently designed for motorbike use on the non-kit engines come with a manual clutch.
  4. illMATTic
    Oct 5, 2012
    27
    That clutch looks nice. Its a bit strong in price though.
    I am trying to not have to use a recoil starter. I hate the look of them.
    Thanks,
  5. msrfan
    msrfan Active Member
    Sep 17, 2010
    1,758
    22
    Yeah, you're right about the price. I've also heard the quality is not the best. The Whizzer guys can tell you more.
  6. wayne z
    wayne z New Member
    Dec 5, 2010
    1,746
    A while back, one of the DIY builders here modified a centrifugal clutch by adding spring loaded pawls that allowed him to pedal start his motor. I think he needed a compression release too to get the motor spinning. After it started, cent force kept the pawls dis-engaged. If you're handy at tinkering and modifying stuff, it wouldn't be too hard to do.
  7. wayne z
    wayne z New Member
    Dec 5, 2010
    1,746
    Also, some of the briggs powered builders have built kickstarters for their motors.
  8. bigbutterbean
    Jan 31, 2011
    2,417
    I have a 98cc Lifan 4 stroke. I didnt buy mine at home depot, but their specs say it has auto-decompression for easy starting. I dont know if thats an action of the recoil starter and the flywheel, or how exactly that works, but maybe somebody here knows what that means.
  9. wayne z
    wayne z New Member
    Dec 5, 2010
    1,746
    The auto-decompression mode is built into the camshaft assembly. The Predators and most of the Honda's ect nowdays have this
  10. bigbutterbean
    Jan 31, 2011
    2,417
    Oh ok, so if you modded the clutch for pedal start on one of those engines, thats all you would need to do then.
  11. wayne z
    wayne z New Member
    Dec 5, 2010
    1,746
    Don't know fore sure. You may need a cylinder head compression release, or a custom manual controlled valve lift device, as these have much more effect than the factory built in camshaft operated ones.
  12. bigbutterbean
    Jan 31, 2011
    2,417
    oh ok I'm just getting into 4 strokes lol so I dont know too much about this kind of stuff.
  13. maniac57
    Oct 8, 2011
    4,486
    The only kind I know of are motorcycle parts. VERY expensive for this hobby...
    Google Baker transmissions.
