Is it worth it
Discussion in 'Motorized Bicycle General Discussion' started by oylavabeer, Jun 13, 2011.
  1. oylavabeer
    oylavabeer New Member
    Jan 9, 2009
    214
    With the cost of a new replacement engine it doesnt seem worth the effort of swaping crank shaft seals pistons etc. I only say this because thats what I recently did and the time I wasnt riding wasnt worth it. All that said I love tinkering.
  2. Al.Fisherman
    Al.Fisherman New Member
    Sep 9, 2009
    1,966
    If, can you afford the extra between a engine and the parts needed, then if you can the complete engine is the best option. Plus you will have spare parts on hand. I myself wouldn't rebuild the engine. I have had 1 engine tear up (not my fault, bad head gasket...piston, rings, cylinder) and I replaced it. I know that all I needed was the upper end, but should I have another go I have a case intact, no waiting on parts, low down time.
    Prices are off Ebay... Most from BGF..which I wouldn't buy so much as a screw from them.
    Engine..Case inc piston $67.00
    Parts
    Piston w/rings $20.00
    Crank..$32.00
    Crank bgr (2) $10.00
    Gasket set.. $13.00
    Wrist pin brg..$13.00
    Seals.. (2)...$12.00
    Head gasket..$5.00 TTL $105.00 +/-
    So NOT worth it at all.
    #2 Al.Fisherman, Jun 13, 2011
  3. Mr.Gadget
    Mr.Gadget New Member
    Nov 9, 2010
    96
    Al.Fisherman,
    It sounds like you had a bad run in with BFG. I have done a little bussines with BGF with out any problems. Could you share your experiance with them?
  4. DaveC
    DaveC Member
    Jul 14, 2010
    970
    The 66 cc kit I bought from them came with a defective motor. It flat would not start inspite of a fat blue spark and fuel flow. The replacement motor fired the first time....
    Bought a 49 cc. It was dead, too. I gave up on the freaking Chinee motors and got a Morini.
  5. Al.Fisherman
    Sep 9, 2009
    1,966
    This belongs in another post, I don't want to hijack this mans post.
  6. oylavabeer
    Jan 9, 2009
    214
    Thats what I was thinking Ron
  7. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    its cheaper to just get a whole bottom end or whole top end and if you get it from gasbike you get free shipping.
  8. r00t4rd3d
    r00t4rd3d New Member
    Aug 2, 2010
    310
    Its good to have 2 engines. Ride the crap outta one till it breaks then put in the 2nd while you fix up the first. That way you will always have a back up ready to go and something to tinker with.
