is it necessary to clean the gas tank before first run?
Discussion in 'Motorized Bicycle General Discussion' started by ncfootballchamp, Oct 19, 2010.
  1. ncfootballchamp
    ncfootballchamp New Member
    Aug 29, 2010
    43
    is it necessary to clean the gas tank before the first run?
  2. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    17
    I always do, I always add a little fuel before mounting the tank and dump it out for a quick flush.
    *Let me add I always remove the petcock when doing this so I dont add any junk to the tank filter.
    #2 Dave31, Oct 19, 2010
  3. hurricane
    hurricane New Member
    Sep 20, 2010
    75
    what Dave said...
  4. 2door
    2door Moderator
    Staff Member
    16,310
    A quick look with a flashlight should tell you if there is a lot of rust/crud in the tank. If it looks relatively clean then use Dave's advice. If there appears to be rust on the interior surfaces then dump in a hand full of course sand, lead shot or any abrasive material and give the tank a few minutes of hard shaking then rinse with hot water and allow to completely dry before installing it. Many of the kit supplied tanks, especially the chrome plated ones will have rust inside that you need to get rid of or you'll have problems with clogged fuel filters, needle valves and other problems. Most of us like to use an external fuel filter betwen the tank and carburetor to assure a clean fuel supply to the carb.
  5. DOC BOLM
    DOC BOLM New Member
    Aug 21, 2008
    681
    Do you take a bath before you go out,go ahead and give the tank one also.
  6. WildAlaskan
    WildAlaskan New Member
    Sep 30, 2010
    581
    you know i might have gotten lucky cause i never cleaned my tank out or my dads when i built them but thats cause i didnt know i should you may get lucky like me not a bit of rust or might not so i recomend cleaning the tank i will for sure on my next build
  7. Drewd
    Drewd New Member
    Jul 25, 2008
    425
    Yes and remove the screen filter which is part of the fuel valve. Install a quality inline filter instead.
  8. WildAlaskan
    Sep 30, 2010
    581
    i removed the screen filture i have a in line filture but it seems that its sort of decaying in there i was considering taking it off and just screening gas befor it goes into tank with panty hose or something
  9. Slowrollers
    Slowrollers New Member
    Sep 8, 2010
    65
    Whats the reason for removing the filter????seems to me it will help keep crap out of the pet cock.....
  10. 2door
    2door Moderator
    Staff Member
    16,310
    I agree. As long as you keep it clean the inlet filter that comes with the kits will indeed help keep dirt out of the petcock. Grit will wear the 'O' rings which will eventually cause the petcock to drain fuel even when shut off. Install an in-line filter between the petcock and carburetor but leave the little in-tank screen on the petcock. Its double assurance against dirt. If it continually clogs then its time to clean your tank and strain your fuel if you're mixing/storing in a dirty container. As far as that goes you might be surprised to see what comes from the gas pump at the gas station. They're not as diligent at keeping their underground tanks, pumps and hoses as clean as you might expect.
    #10 2door, Oct 22, 2010
  11. rohmell
    rohmell Active Member
    Jun 2, 2010
    1,533
    Very true!
    In some countries, it is illegal for stations to pump and sell gasoline for a certain period of time after the tanks have been filled, to allow for all the garbage to settle down.
  12. 5-7HEAVEN
    5-7HEAVEN Well-Known Member
    Aug 2, 2008
    2,364
    I always remove the brass screen and install a FRAM automotive fuel filter before installing my fuel tanks.
    My 4-liter Happy Time gas tank was used, and had sat for a while, before I put it on my bike. I also installed a locking gas cap, which involved filing the notches/tabs on the gas neck to accept the cap. Even though I put napkins inside the tank to catch the filings, I still had to clean it.(I should've inverted the tank while I was filing the gas neck.) After removing the petcock, I filled the tank with water several times and sloshed it around. Then I stuffed several napkins to sop up whatever was left in there. To ensure all water was removed, I stuck a hairdryer nozzle into the neck for several minutes. The tank became very hot, which evaporated any water that had been in there.
    Any leftover metal filings or rust would be picked up by the $5 filter, although I can't see any crud in the see-through FRAM.
