Is a billet pulley available?
Discussion in 'Motorized Bicycle General Discussion' started by skiball83, Dec 17, 2010.
  1. skiball83
    skiball83 New Member
    Nov 18, 2010
    138
    Got a 2 stroke ht 66cc. Ive noticed that on my stock pulley the chain has "eaten" into it to make its own grooves. As I adjust the pulley it will make the chain run erratically untill it seats itself onto its new groove. Has anyone made a billet pulley in place of the factory nylon one. Not interested in anything plastic unless you have tried both and can show the difference and improvement in one or the other.
  2. biknut
    biknut Active Member
    Sep 28, 2010
    6,365
    Chains run on sprockets. Belts run on pulleys.
  3. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    Pulley? I'm guessing you're talking about the chain tensioner roller. The chain should still have about 1/2"-ish of play. It sounds like you've got it set too tight for it to be wearing a groove into it.
    That said, there's a bunch of different materials I've heard about. Roller skate wheel, little sprocket, some other plastics that don't wear.
  4. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,819
    11
    I have not seen one. The nylon pulley wheel is quieter than a billet one, but not very attractive. An aluminum pulley might be a good compromise.
  5. bairdco
    Aug 18, 2009
    6,352
    28
    i know what you can use to make one...
    go to REI or somewhere that has climbing equipment and get a speed block:
    [​IMG]
  6. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    I gotta say that while a "billet" aluminum or any metal roller may last longer - it'd be a vibration nightmare as the chain links rattle over it... but I gotta agree w/Nougat & say it sounds like you've got the chain way too tight. I've the stock one on my first build and it's got thousands of miles on it w/only slight wear.
  7. scotto-
    Jun 3, 2010
    6,530
    6
    I'm still real happy with this steel toothed tension roller.....it doesn't seem to wear at all and it was worn out when I started using it. It's a worn out 11t secondary, freewheel counter sprocket, with the ratcheting pawls removed.....works great and keeps the chain on track so too speak.
    [​IMG]
    URL=http://img132.imageshack.us/i/img1173fm.jpg/][​IMG][/URL]
    [​IMG]
  8. 2door
    2door Moderator
    Staff Member
    16,304
    29
    A metal tensioner wheel? Wow, talk about noise and vibration...Barley Awake is right. It won't matter how well the roller, wheel, pulley, whatever you want to call it spins, there's still going to be a lot of noise produced.
    Use the seach feature, type in 'tensioner wheel' and see what others have done. To date, a good quality urethane skate board, roller blade wheel is the best option. You'll need to groove it to fit the chain so stay away from the coated, two layer type, they come apart, but a one piece wheel works great. Quiet and they last "for-e-ver"...(scene from 'The Sand Lot')
  9. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
    To date the Skate board wheel is the smoothest thing I ever used. Cannot wear them out either. I like them being slightly larger in circumference than the stock wheels as the chain bends less going over the Skate wheel their smooth as silk in this manner!! I have not tried a sprocket yet .
    #9 Goat Herder, Dec 18, 2010
  10. skiball83
    Nov 18, 2010
    138
    All great tips guys thanks alot for the input, and yes I was refering to the tensioner wheel.
  11. scotto-
    Jun 3, 2010
    6,530
    6
    Not too get into debate here Tom, but this set-up is as smooth and quiet as a baby's bum. Double bearings with very little tension as you can see by the angle of the chain....a skateboard wheel or urethane roller are really no better, but equal in the outcome ie. noise and vibration. I've tried them all.
  12. 2door
    2door Moderator
    Staff Member
    16,304
    29
    No argument from me, Scotto. I think what Geoff and I are saying is that a wheel, pully, will be noisy. You're using a sprocket. That's different...lots different than having chain links hit and rattle over a solid piece of metal which might or might not rotate freely with the friction of the chain riding across it.
    By the way...I like your design. Industrial applications typically use a sprocket on chain tensioner/guides. Absolutely nothing wrong with the concept.
  13. scotto-
    Jun 3, 2010
    6,530
    6
    Agreed...a sprocket is way different than any metal roller. A metal roller would rattle your brains looserotfl
  14. epicboy
    epicboy New Member
    Nov 3, 2010
    69
    skate board wheel, bmx tensioner or 29er tensioner would work best from what i have seen. small sprocket tensioner's need to be very precise if you go that route..
  15. 2door
    2door Moderator
    Staff Member
    16,304
    29
    No doubt that a sprocket must be aligned correctly to work properly but exact chain/sprocket alignment is essential for proper operation no matter the tensioner style. Any lateral misalignment is an invitation for trouble. This is true if using a tensioner or not.
  16. trackfodder
    trackfodder Member
    Sep 8, 2008
    347
    I think the solution is quite simple if we are doing business with a China Girl type. You can't make proper tension with the drive chain do to the peddle chain, right? Simply put an offset link in your peddle chain and remove whatever is necessary in your power chain and heave the tensioner. I haven't done it yet because I am lazy and my idler hasn't crapped out yet. I did buy the half link, but could care less about riding it since I am completing restoration of a 56 Matchlless G-80S 500cc single and have an 1100 to ride if I need to go somewhere and it is d---ed cold anyhow., Thank God for battery tenders.dnut
  17. 2door
    2door Moderator
    Staff Member
    16,304
    29
    Your idea has merit but unfortunately there are frames that will not allow for running without a tensioner. Narrow chain stays on some frames and/or fat tires require the tensioner to keep the chain from hitting. If you have the style of frame that allows you to go without a tensioner/chain guide, then by all means, go for it. Nevertheless there are those who do not have that choice. For them, they need an alternative to the poorly designed mount of the kit supplied tensioner. That's who these discussions are aimed at.
  18. epicboy
    epicboy New Member
    Nov 3, 2010
    69
    my point is this - unless your some rich kid that can afford all the nice precision parts - then precision won't really be an issue. As for me and I'm sure a few others, you gotta work with what you got! The china kit is a work in progress to say the least. Don't get me wrong - if it wasn't for the china girl i probably wouldnt be here...CHeers guys
