Intake
Discussion in 'Motorized Bicycle General Discussion' started by Mrakulous, Dec 9, 2009.
  1. Mrakulous
    Mrakulous New Member
    Mar 9, 2009
    57
    I bought the cnc intake manifold from whats his nuts, and since it is straight, i have interference with the bolt that guides the clutch cable. So i have my carb slightly askew. Anyone know how to remedy this problem?
  2. Bikeguy Joe
    Jan 8, 2008
    11,529
    Yeah, call what his nuts.
  3. Motor Boys
    Motor Boys New Member
    Nov 6, 2009
    179
    Take out the guide and file down the threads abit so it sits down lower and you should be good.
  4. wes
    wes New Member
    Aug 17, 2009
    207
    I got mine in the mail yesterday, the web site says that in order for this intake to work you have to remove that bolt and cut a quarter inch off of it then replace it, put the bolt in a vice and try to cut it straight and you will be fine, my question is how does it run with the carb not level, i am wondering if i have to level out my motor so the float doesnt stick as the stock intake is bent slight over 90 degrees to help level out the carb. Good luck, and whats his nuts has very good custumer service and would be glad to help you if you need it, I beleive his name is Justin!!!
  5. Tcams
    Tcams New Member
    Oct 18, 2009
    412
    Or Jim
    MANIC Mechanic Parts.htm
  6. Creative Engineering
    Sep 20, 2008
    1,668
    I have been reduced to being referred to as "what's his nuts" on a public forum with over 12,000 members...awesome...laff
    Yes, as miraculous as it may seem, I guess I'm going to have to take out the time to make an installation guide for my CNC machined intake. Please don't ask me to write a guide on how to chew gum...I will surely end up in the puzzle factory.
    Jim
  7. DOC BOLM
    DOC BOLM New Member
    Aug 21, 2008
    681
    There are 11,999 of us who know your real name.Some people would gripe if you hung them with a new rope.H.D.
  8. Finfan
    Finfan New Member
    Aug 29, 2008
    871
    You mean this ISN"T the puzzle factory!!!! :eek:
  9. wes
    wes New Member
    Aug 17, 2009
    207
  10. Creative Engineering
    Sep 20, 2008
    1,668
    Wes,
    I made the first intake just before Christmas last year. I needed it for the bike shown below.
    The engine was mounted fairly level, so the orginal intake would have positioned the carb, angled down.
    Your engine does not have to be perfectly level in order to use the intake I make. It's usually fairly easy to level out the engine a little so that the carb isn't angled way up.
    The "O"-ring seals the connection between the carb and intake, which makes for a good idle...no more vacuum leaks.
    The short, straight through, design is far superior for obvious reasons.
    Jim
  11. Riding Rich
    Riding Rich New Member
    Aug 14, 2009
    349
    I love that intake.
    No problems from slight tilting here.
  12. wes
    wes New Member
    Aug 17, 2009
    207
    Its on, just waiting for the RTV to set up a little more, I cut the bolt down a quarter inch and it went right back in with out cross threading, i turned my pit cock on and pushed the plunger to see if the float was working and everything works just fine, the float stoped the flow of fuel!!! Ill give it a few more minutes before i fire it up!!!
  13. wes
    wes New Member
    Aug 17, 2009
    207
    Fired it up and it works great, better throttle response, more power, better idle for sure, thanks Jim and Justin for an awesome intake!!!
  14. Creative Engineering
    Sep 20, 2008
    1,668
    Excellent Wes!
    Wes, Riding Rich, Mrakulous and the many others who have bought my intake...thank you!
    Pirate Cycles is an authorized reseller of Manic Mechanic parts...Justin knows our products first hand because he uses them on his own bikes that he builds for customers.
    If you guys have questions about the installation of a Manic Mechanic part, you can contact either one of us for help no matter who you actually purchased from.
    Jim
  15. troyboy
    troyboy Your East Coast Gasbike Connection
    Apr 18, 2009
    171
    Whats his nuts.. It kinda has a ring to it..
    Jim.. I want the gum chewing gum guide in a PDF please..
    Justin
  16. NunyaBidness
    NunyaBidness Active Member
    Jun 29, 2008
    1,062
    YES! oh yeah, if you could include instructions on how to chew it while walking that would be greatly appreciated.
  17. turtle tedd
    turtle tedd Member
    Jul 18, 2009
    153
    yo .....Whats His Nuts.....could you also provide a pictorial instruction sheet on how to get on my MB since it is usualy parked against the wall
  18. Riding Rich
    Aug 14, 2009
    349
    Jim
    Your work is outstanding.
    Please keep it up.
    Thanks
    Rich
  19. Riding Rich
    Aug 14, 2009
    349
    PS.
    Can u make me a set of billet skis to mount to my front forks?
  20. Space Cowboy
    Space Cowboy New Member
    Sep 22, 2011
    i have damm good O-Rings for them CNC'd intakes.
    Gas, Oil, Temp resident.pino.
