Install new high tech throttle, bike runs 1 day
Discussion in 'Motorized Bicycle General Discussion' started by yodar, Nov 21, 2010.
  1. yodar
    yodar New Member
    Jul 26, 2010
    147
    Installed new throttle & cable with pulley.
    Bike ran fine 1 day then gas started pouring thru the air cleaner.
    I re-seated the needle, clip about 1 mm down from end, and piston and tore open the carb and found no filth,anywhere, but it still leaked ags on reassembly and use
    All this seems to be from something I did when i replace throttle cable and throttle grip with a new, nicer one
    WHO will FedEx or UPS me a carb? My principle suppliers will NOT UPS or FedEx to me. USPS gets stolen here
  2. Mind_Reader7
    Mind_Reader7 New Member
    May 1, 2010
    393
    Bend the float tab a little.
    Norms carb guide tells you how.
  3. Black_Moons
    Black_Moons New Member
    Oct 25, 2010
    207
    Yea its either the float, the needle, Or your carb is unlevel now. (And then its basicly still the float)
  4. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
  5. Mind_Reader7
    May 1, 2010
    393
    Also, what do you mean by high tech throttle? Lol.
  6. yodar
    yodar New Member
    Jul 26, 2010
    147
    It has a REAL pulley in it ! HAR !
    I think the heavier and shorter cable transmitted a little too much force and the needle bent the lil' tab.
    As soon as I can get some proper metric bolts to re-attach the carb/maniforld
    to the bike my NEW carb will have arrived (WED)
  7. timboellner
    timboellner Member
    Apr 1, 2009
    435
    I don't know of any carbs with pulleys in them.
    Throttle cables pull the slide up, spring inside pushes the slide down when throttle is released.
    The only force which acts on the float tabs is the float itself.
    You should only bend the float tabs as a last resort.
    Check the little needle that the float pushes up into the "seat". It shuts off the gas from entering the float bowl when it's full.
    Clean that mechanism out with carb cleaner after disassembling it.
    One tiny chunk will prohibit it from seating correctly.
    The simple NT carb is the easiest one to adjust, the others will try your patience.
    TIM
  8. Mind_Reader7
    May 1, 2010
    393
    Ah, I had a pulley throttle, they're quite nice. The only problem I had with mine is the cable jumped off the pull and got snagged, so I was stuck at full throttle. Pulled in clutch/kill switch. The good thing is it had thumb screws for the top, so I could put it in with no tools.
  9. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    gas pouring out the air cleaner? does the float have a crack and full of fuel?
  10. Mind_Reader7
    May 1, 2010
    393
    The air cleaner probably wasn't leaking, just had some fuel on the tips due to the poor design of the carb/no reed valve.
