idler pulley bolt thingy
Discussion in 'Motorized Bicycle General Discussion' started by thxcuz, Apr 29, 2015.
  1. thxcuz
    thxcuz Member
    Jul 26, 2012
    288
    I need to move my idler pulley a few mm to the right, is the bolt thingy that connects the pulley to the bracket a common hardware store product or is it something that is unique? I need a slightly longer bolt thingy and use a few washers to get my chain lined up.
    Sorry if this is kind of vague...I'm on my third gin and tonic
  2. Trey
    Trey $50 Cruiser
    Jan 17, 2013
    1,432
    Well since I'm on my second rum and coke, I think I should respond :)
    If I understand you correctly, then yes. That should be a fastener you can find at a decently stocked hardware store.
    Are you not able to bend that bracket in a way that keeps your chain aligned, and still get's it in to where you need it? I would try that first, if it's an option.
    Good luck!
  3. thxcuz
    thxcuz Member
    Jul 26, 2012
    288
  4. Trey
    Trey $50 Cruiser
    Jan 17, 2013
    1,432
    You should easily be able to make the required adjustment with that one.
    You did right getting rid of the kit part- junk.
    I actually take whatever extra time and headache needed to run my chains without one at all. Never a problem so far.
  5. 2door
    2door Moderator
    Staff Member
    16,301
    26
    The concept is the best choice if you must use a tensioner. Spanning the seat and chain stays will assure the tensioner stays where you put it and can't loosen and rotate into the spokes with the expected results.
    As for the kit supplied tensioner brackets, almost without exception they will need to be bent/twisted to some degree to achieve proper chain/sprocket/tensioner wheel alignment.
  6. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,517
    48
    I sometimes cut a "C" shaped piece of old handlebar to put under the clamp of those - it'll move it a bit toward that side & give a better grip on the frame at same time
    #6 crassius, Apr 29, 2015
  7. TheNecromancer13
    Jan 21, 2015
    603
    10
    I just put my chain on the underside of the pulley instead of over it, so the chain pulls it straight instead of pushing it into the spokes. Works like a charm.
  8. crassius
    Sep 30, 2012
    3,517
    48
    seems a good idea when/if the frame gives you room for that
