Ideas how to contain carb spit-back
Discussion in 'Motorized Bicycle General Discussion' started by Alajoyn, May 9, 2010.
  1. Alajoyn
    Alajoyn New Member
    Sep 28, 2009
    71
    Anyone have advise on an appropriate air filter system that will better contain the fuel spit-back that is inherent in the HT engine design? I have fuel that accumulates at the bottom of my stock air filter system on the stock NT carb. I realize that with a single cylinder single carb set up on a 2-stroke you'll have this issue, but those of you with custom paint, what do you do to prevent dripping and getting onto the motor and it's fins...except a wipe rag every 5mi or so.
    Ideas?
    Thanks,
    Robert
  2. bairdco
    Aug 18, 2009
    6,401
    49
    i wipe mine with a rag every 5 miles or so.
    actually, i don't think there's a cure for it. if you got a bigger filter to soak it up, it'd just get saturated and have to be cleaned out more often to provide good airflow.
    the right mixture helps a lot. i use 100:1 opti 2 oil, and the oil doesn't clog up in the filter and leak out as much.
  3. 2door
    2door Moderator
    Staff Member
    16,310
    I concur with Bairdco. It's a 2 stroke and intake blow-back is normal. Either live with it or keep a rag handy, or go for a 4 stroke engine.
    Some of the more exotic, synthetic oils. Opti-2 is an example will reduce the amount of oil in the intake by some degree but you'll always have it. Sorry, just a fact of life.
  4. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    Would a plastic overflow tube from the bottom of the air-filter housing going down below the frame help ? (as seen on 4 stroke carbsw on a thread here )
  5. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
    On one of my builds I had played with a boost bottle, and put of all things a Right Guard deodorant cap. It matched the color of the bike almost. Last I used pantie hose about 6 plies with a cable tie around the end. It really wasn't all that pretty but the oil was contained between the boost bottle and the added depth of the cap I used.
    I think a bigger deeper filter might help but have not tried it without the boost bottle.
    And no the boost bottle doesn't give any dramatic power just makes the throttle a little more responsive.
  6. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    To really fix it, you'd need to add a reed valve.
  7. Bikeguy Joe
    Jan 8, 2008
    11,529
    Just don't route it to oil your tire.
  8. Alajoyn
    Alajoyn New Member
    Sep 28, 2009
    71
    Oh yeah, I like the idea of fitting tube to bottom of air filter housing.
    I could fabricate a housing that fits tightly around and seals at the carbs front face and make the new housing with a little "basin" with a ferrule fitting soldered to attach a tube to. I can fab it from copper shimming stock and solder it together with an internal flange to press the filter against, then cap it mebe even with the same cover & longer screws. Hmmmm new things to invent.
    Thanks for the idea guys.
    Robert
    Hmmm or would enlongating the intake manifold with a slight "s" help eliminate it??
    More to make ya go hmmmm
  9. CoastalCruiser
    CoastalCruiser New Member
    Apr 28, 2010
    338
    ya beat me to it Corgi. That's what I'd do.
  10. Drewd
    Drewd New Member
    Jul 25, 2008
    425
    Believe it or not, this is the only instance I'd recommend a boost bottle for a HT. Mine had less spitback with one but no improvement in top end performance or speed.
  11. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    Or you could connect a hose or rubber boot on the end of the aircleaner and run it to a airbox,it contains the oil and gas and holds it in the aircleaner housing. i know this works cause i tryed it.
  12. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    Thinking about the boost bottle,it is a vaccume thing,,,,,so if the tube from the bottom of the air filter was placed in front of the carb intake the vac.from the engine running would suc the oil mix that was collecting in the tube from the bottom of the air filter keeping it clean
  13. Cabinfever1977
    Mar 23, 2009
    2,290
    You would also have to have the aircleaner filter sealed tight up against the housing or gas/oil will leak from the cracks. You also have to have it removable to clean it.
  14. Fabian
    Fabian New Member
    Sep 9, 2009
    168
    There's only one solution to eliminating intake reversion, and that's to fit a reed valve onto the intake port.
    This method will not only solve reversion issues but will increase low and mid range rpm performance.
    Now if only someone can design and market a reed valve intake conversion system, i'll buy the damm thing at an instant.
    Fabian
  15. Alajoyn
    Alajoyn New Member
    Sep 28, 2009
    71
    Yeah I know what your talking about.
    I have a buddy that designed his own external reed mod for an old Mercury 3cyl outboard in order to increase performance over the stock reed system. I've seen it. Wow it made a difference, Kinda like runnin the old Cleveland 351 heads I used to play with.
    Well, a grinder, an aluminum block and lots of epoxy'll get ya there...eventually.
    Robert
  16. jawbreaker
    jawbreaker New Member
    Jun 30, 2010
    10
    how is a reed valve work?
  17. NunyaBidness
    NunyaBidness Active Member
    Jun 29, 2008
    1,062
    A reed valve fits in the intake between the carb and the cylinder. This allows fuel to get sucked into the cylinder yet closes to prevent any fuel from going back towards the carb. Basically a reed valve is a one way valve.
  18. Venice Motor Bikes
    Mar 20, 2008
    6,228
    32
    K&N style filters tend to soak up the oil. (^)
  19. ferball
    ferball New Member
    Apr 8, 2010
    599
    The reed valve sounds interesting, is there any temperature issues to worry about when attaching stuff to the intake? Just curious as this may need some exploration on a rainy saturday afternoon.
  20. 5446
    5446 New Member
    Jun 7, 2010
    84
    Ya and I would be right behind you!
