I need some great tips here please!
Discussion in 'Motorized Bicycle General Discussion' started by NerpAngel, May 26, 2010.
  1. NerpAngel
    NerpAngel New Member
    Sep 28, 2009
    141
    This is my Trek 4300 and I just recently bought a shift kit and a large universal mount from SBP. Now.. I've seen one other guy on this forum with the same bike "Hawaiian Ed.. or whatever he name was) so I know this is probably possible.. I don't know where to go from here (look at the pictures). I can't seem to get this puppy to mount correctly! If it's in one spot the carb will fit, but the front motor mount won't. If the front motor mount fits then the carb fits without the air filter. See what I mean? Anyone here and any suggestions on how I can fit this setup?! Any help would be greatly, greatly appreciated.
    Oh and if this is posted in the wrong section you can move it if you want. I just wasn't sure where this fell under.
  2. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    I would go ahead and mount the engine, then fab up a new intake or mod that one, maybe a 90% copper pipe fitting on the end of the intake and have the carb on the side or you could just shorten or buy a short straight intake. Or you could legthen the intake with a longer straight pipe or hose to go past and around the frame then mount carb.
    Heres a hint: bring intake and carb to store when buying pipe,hose,or pipe fittings to make sure everything fits together.
    But if you want cheap and easy just rubberband a airfilter without the housing around the end of the carb.
    Did you check the sparkplug and boot clearance?doesnt look like much room.
    #2 Cabinfever1977, May 26, 2010
  3. NerpAngel
    Sep 28, 2009
    141
    You know anyone that sells different types of intakes? I'm not much of a modder :)
  4. Cabinfever1977
    Mar 23, 2009
    2,290
  5. NerpAngel
    Sep 28, 2009
    141
    Ya I know about his. Do you know how long it is?
  6. Cabinfever1977
    Mar 23, 2009
    2,290
    I have no idea, but you could also just cut yours shorter using a hacksaw,remove from engine first,don't want metal shavings in your engine.
    #6 Cabinfever1977, May 26, 2010
  7. NerpAngel
    Sep 28, 2009
    141
    true! i could try that. ima go experiment.
  8. taddthewadd
    taddthewadd New Member
    Mar 1, 2009
    339
    The problem seems to be the frame size. The other guy on the forum might have the same bike but a larger frame. A frame is measured from the center of the bottom bracket (the round part at the bottom of the frame) to the top of the seat tube (where the seat post enters the frame). I would say it should be a minimum of 18-19 inches to fit the engine comfortably. I could be wrong but your frame looks closer to 16 inches. Some frames say the size in inches or just measure it with a tape measurer. Let us know.
  9. Technocyclist
    Technocyclist Motorized Bicycle Senior Technologist
    Jul 7, 2008
    463
    sell the small frame then get a larger frame...
  10. NerpAngel
    Sep 28, 2009
    141
    Do you think I could just offset the carb? It seems to be the only part that is getting in the way.
    And I'll go measure the frame.
  11. dag_29307
    dag_29307 New Member
    Jul 1, 2009
    296
    Offsetting the carb. should pose no problem/ I know someone in this forum has a pic of their bike with a tube that extends past the seat post down tube and my carb. actually is tilted about 5 degrees because I use a 24" mountain bike and the throttle cable doesn't clear the top tube. So I don.t think a little thing like putting a 90 degree elbow would hurt as long as your air cleaner isn't blocked by your leg or anything.
    #11 dag_29307, May 27, 2010
  12. NerpAngel
    Sep 28, 2009
    141
    where's your air filter????
  13. dag_29307
    Jul 1, 2009
    296
    First photo shows location of air cleaner housing.
    Second shows face of air cleaner.
    Third shows face removed to expose sponge inside.
    Fourth shows backing leading into carb.
    Need anything else just let me know.
  14. NerpAngel
    Sep 28, 2009
    141
    haha ya, where did you get this? :) I would like one!
  15. dag_29307
    Jul 1, 2009
    296
    it was part of the kit I ordered over two years ago when I bought my first Motor kit. =)
  16. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
  17. drhofferber
    drhofferber New Member
    Jun 22, 2008
    307
    yes the offset intake works ok...they now have them in stock...als0 you can purchace 2 or three intakes from jim in the scrap bin...i grind the back part to 40% and it while fit great with a regular mounted engine....i fill up the holes with instant steel...grind and than drill new holes...when you order from the scrap bin, ask for the shortest intake possible...the shorter the better...i have tried the spooky tooth reamidy and you loose a little power...or at least i did...good luck...Dennis
  18. NerpAngel
    Sep 28, 2009
    141
    So extending the intake like spooky's decreases your power a little? Can anyone else confirm this?
    And dag, do you know where I could purchase just that piece from where you bought it? Or is it just a kit thing?
  19. drhofferber
    Jun 22, 2008
    307
    just checked on manic mechanics sight...no scrap bin now...ha...jims intakes he has on his sight are short...perfect...or you can get it from pirate...if you want my offset intake, give me you address and i'll send it to you...(private message)
  20. dag_29307
    Jul 1, 2009
    296
    #20 dag_29307, May 28, 2010
