I just got a crazy idea
Discussion in 'Motorized Bicycle General Discussion' started by biknut, Oct 31, 2010.
  1. biknut
    biknut Active Member
    Sep 28, 2010
    6,379
    Has anybody ever thought about making China Girl with twin engines?
  2. msrfan
    msrfan Well-Known Member
    Sep 17, 2010
    1,779
    36
    I have a couple of tandem frames that may accommodate two motors. Check out "Double Vision Whizzer" on Google.
  3. Fulltimer
    Fulltimer New Member
    Aug 13, 2010
    1,322
    Twin motors with twin carbs!!dance1
    Terry
  4. killercanuck
    killercanuck New Member
    Dec 17, 2009
    1,749
    I'll see your two and raise you three! :) I can't find the original post, but I held onto these pics, because they're awesome. Triker's have a lot more room to play with(most of the time). Although you could go ht/friction/elec hubs if you don't want to go tandem...
    edit-found the post:
    http://motorbicycling.com/f44/3-ht-motors-trike-22358.html
    #4 killercanuck, Oct 31, 2010
  5. Russell
    Russell Well-Known Member
    Apr 19, 2009
    1,205
    25
    I also saw that triple motor posting. There were a lot of comments about keeping the engines in synk for max power. However I don't care how you cut it that must be awsome! Free wheels would eliminate the engines draging each other.
    It looks like the Acme twin will never be a reality(bummer) not because of the power but for the look would be great on Board trackers.
    With a tandem I woulden't even worry about synking the engines. It would be a great project. Would live to see pictures.
  6. 5-7HEAVEN
    5-7HEAVEN Well-Known Member
    Aug 2, 2008
    2,364
    I had that crazy idea years ago.dance1
    I bought an old Schwinn Heavi Duty frame, flat-plate OCCC Happy Time mounts and two HT engines. At that time, SBP shift kits weren't made, and I ash-canned the projects.:-||
    Might try it again.
  7. Russell
    Apr 19, 2009
    1,205
    25
    Dam, You give up two easy(LOL)
  8. 5-7HEAVEN
    Aug 2, 2008
    2,364
    It was the two clutch levers, two brake levers and two throttle levers ANNND the engines' width that stymied me.
    So I blew through twin-engine(3hp each) friction drives, then 5hp friction drive, then finally 5hp frame-mount shift kit.dance1
    Not a quitter; I just chose easier paths to power and high speed, lol.xct2
