I broke my cherry!
Discussion in 'Motorized Bicycle General Discussion' started by skaliwag66, Oct 17, 2010.
  1. skaliwag66
    skaliwag66 New Member
    Feb 4, 2010
    17
    ...and finally got a gas cruiser (what did you think I was talking about?);).
    I am completely new to anything about combustion engines and especially these kits. Everything seems to be sound and my first ride was a 50km ride across the city of Toronto. I have a few questions however about operation, care and what to do in case of failure. Sorry if these questions seem dead basic but I really have no idea what I'm dealing with here since I am coming off an electric bike and basically an electric/electronics geek. I am mechanically inclined though and have no problem working on it when the time comes.
    Operation:
    -When coasting, am I causing damage by leaving the clutch engaged (lever out) or do I have to disengage it?
    -The seller explained the choke but I am still not clear about using it. What's the procedure for warming up the engine and using this lever? He said it has to stay closed when the engine's 'cold' and the open it quickly when it warms up.
    -I went full throttle a couple times on my first ride and I wonder if that caused any damage. How often can I safely go full throttle?
    -There is no chain tension wheel but the bike seems to run fine. Is it essential?
    -Sometimes I engaged/disengaged the clutch too quickly. Is that bad?
    Maintenance and Failures:
    -I leave this bike in the back yard and since winters around the corner, if leaving it out in the cold weather going to affect the bike?
    -What's the first problem that I can expect to encounter from this bike? Or, what the most common failure?
    -What the longest distance I can travel (provided I have enough fuel) before I can expect a failure (based on common experiences)?
    -Do I have to, one day, take the whole thing apart and clean it or replace anything?
    I probably have more questions soon but these are the ones I have off the top of my head.
    Thanks for your answers and I'm looking forward to learning more from this community!zpt
  2. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    If you're going to decelerate or coast, pull the clutch. Engine braking with a two stroke is bad.
    Choke: lever up to start, lever down as soon as you can.
    Full throttle? To me, no problem. Ride it like you mean it.
    No tensioner? As long as the chain has about a half or three quarters inch play when you're standing still and it doesn't jump off, this is good.
    Let the clutch handle out gently, so as not to wear the clutch pads too quickly. Pull the clutch handle as fast as you like.
    Back yard over the winter: put a cover on it, and expect it to start harder in the cold. Check your tires very regularly. Check tightness of nuts frequently, as the wide hot/cold cycling will tend to loosen things. Don't overtighten; a torque wrench is a good idea.
    First problem: dirty air cleaners element. Squeeze the fuel out if it occasionally. The magnetos tend toward failure, too, but that's not a certainty.
    Mean time to failure? I don't know the answer to that. I only have one, and the engine has been fine for 500 miles.
    Unless something fails, you should never have to take the engine apart. You may need to clean the carb occasionally, with disassembly of it.
  3. skaliwag66
    Feb 4, 2010
    17
    hi
    Thanks for the reply!
    I knew engine braking would be a problem and I didn't do it much on my ride because it slowed too hard.
    How often, would you say, should I clean the air cleaner and carb and how do i clean them?
    and is the chain slack measured from the top or bottom where the tension wheel would be?
    #3 skaliwag66, Oct 17, 2010
  4. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    Chain slack will be on the bottom. For the stock carb, two screws hold on a black cover on the back of the carb. Remove the screws and the cover. There's a foam element inside. Squeeze it dry with a rag, replace.
    Carb cleaning, if you've let the bike sit unridden for the winter months, clean it in the spring. If you're going to store it for the winter, drain the tank and the fuel bowl before putting it up. If you ride it often, clean the carb when it starts getting sluggish.
  5. skaliwag66
    Feb 4, 2010
    17
    thanks again. one more question. what exactly is the purpose of the tensioner? Is it used just to keep the chain from smacking against the bike frame? Does it help the bike run smoother/faster?
  6. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    It's to make sure the chain has the right amount of slack. Some frames need one to keep the chain off the frame, but most don't.
  7. skaliwag66
    Feb 4, 2010
    17
    sorry one more :)
    what type of spark plug should i get
    Canadian Tire only has generic ones not NGK
  8. Tim_B_172
    Tim_B_172 New Member
    Aug 26, 2009
    251
    There are a few opinions on spark plugs. Most people use NGK of one model or another. I use NGK B5HS, and you can find them on line with a little help from you're friend Google. I recommend buying two or three just so that you have an extra if one day you suddenly realize that you need it.
  9. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    NGK is really the plug you want. B6HS is the middle heat range. 5 is a bit hotter, if I remember correctly. Mail order them if you have to.
  10. meowy84
    meowy84 New Member
    Jul 18, 2009
    238
    My Canadian Tire (in Thunder Bay, Ontario) carries all common brands like Champion, Bosch, NGK, etc. You have to check in their small engine/lawnmower section, not the auto section. I have the NGK B6HS myself which was the spark most suggested to me by members of this board. I'm sure 'Crappy' Tire carries it. However, I got my plug from Sick Bike Parts because I was also ordering a few other parts including the dual pull brake lever.
  11. skaliwag66
    Feb 4, 2010
    17
    Crappy Tire indeed! :D I hate the Canadian Tire money and reaching into my pocket thinking I'll pull out a 20 only to pull out a 5 cent bill. Anyway thanks for the suggestion. I wasn't sure they had any NGK plugs when I checked online. There's also a NAPA store not too far from me where I can grab one.
