How to remove front mount studs?
Discussion in 'Motorized Bicycle General Discussion' started by The Busted Nut, Aug 4, 2011.
  1. The Busted Nut
    The Busted Nut New Member
    Aug 2, 2011
    96
    So how do i do it? Im building it now and need help!
  2. Al.Fisherman
    Al.Fisherman New Member
    Sep 9, 2009
    1,966
    Is any of it sticking out..if so Vice Grips.
    NO..Couple of options..Left handed drill bit, or ordinary drill and use easy out. REPLACE all your studs with Metric 8.8 (USS Grade 5)
  3. The Busted Nut
    Aug 2, 2011
    96
    I got the drill and tightened it onto the stud. Then i went in reverse. worked like a charm!
  4. decoherence
    decoherence New Member
    Aug 23, 2010
    476
    if the studs are not too screwed up, put two nuts on the stud then tighten them together super tight. give your self room from the base.
    then after they are tight together. unscrew the nut closest to the base.
    if you tightened the nuts together enough, it will unscrew.
    most people drill & retap. better sooner than later.
    i used 1/4-20. only for the reason that it is easier to get in stainless.
    many will say to not use stainless because it is a little weaker than grade 5.
    be careful with the front mount. there isn't much "meat" next to the stud hole.
  5. Al.Fisherman
    Sep 9, 2009
    1,966
    decoherence ... Yes stainless is brittle, I find that the best all around stud will be Metric 8.8 (USS grade 5) The stock studs/nuts are soft, and the 8.8 is stronger then the cast aluminum, so don't over torque.
  6. leanright
    leanright New Member
    Aug 12, 2011
    Hey I'm new to the forum. I just got my engine today from bikeberry. I did the same exact thing just now and it worked. I decided to get longer studs instead of drilling thru the frame. Good idea !
  7. Al.Fisherman
    Sep 9, 2009
    1,966
    Longer studs might not be the solution. The mounts needs to be flush or you could take a chance of snapping them off...
    Look through these pictures....
    Engine Mounting pictures by Ron-Becker - Photobucket
  8. leanright
    Aug 12, 2011
    it should be flush. i have to file down the water bottle holes in the frame but the motor mount looks like it'll sit there pretty flush. thinking i can use some rubber between the frame and mount to close any gaps.
  9. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
    Might read this link. http://motorbicycling.com/f6/rubber-not-27364.html
