how to get the magnet off the crank???
Discussion in 'Motorized Bicycle General Discussion' started by sparrow, May 1, 2012.
  1. sparrow
    sparrow New Member
    May 1, 2012
    19
    hi guys im new to this forum, and new to these little engines im currently on my second and third build simultaniously and im in the middle of upgrading the oil seals and crank case bearings and am at a loss as to how to remove the magnet from the crank so i can seperate the two halves of the crank case to acces the bearings and seals?? im really at a loss here so any help would be appreciated :-||
  2. DaveC
    DaveC Member
    Jul 14, 2010
    970
    Hi new guy. :) A gear puller is what you need to do it the easy way. 2 hooked flat bars attached to a crossbar with a threaded bolt. The hooks go under the magnet and the threaded bolt applies tension to the crank to pull the magnet off. A harder way is to use two screwdrivers or prybars on either side of the magnet. Thread the nut on only until it's flush with the end of the crank then give it a whack with a hammer but not like your driving nails, semi gently. It's best to have someone help you with that so one of you holds the screwdrivers under the magnet, prying up as you hold the block and whack the nut, it should pop loose.
    But really the gearpuller works better and you will need a puller for other things, too. If there's a used tool place near you I'm betting you find one there or at least a cheaper new set. Don't get one too big or the arms will never fit under the magnet.
    http://www.smarter.com/se--qq-gear+puller+tool.html
    One like the puller on the right of the second row is best. The others are too thick to fit in the space you have to work in.
    #2 DaveC, May 1, 2012
  3. sparrow
    sparrow New Member
    May 1, 2012
    19
    yeah i thought as much haha, i have automotive pullers but nothing that small to fit under it. its ok, ill hunt around and find one tomorrow because ill need it for when i replace the bearings and seals in my RSE HP3 engine when it arrives in the mail this week. i guess the chopper goes on the back burner for another few days.
    thanks for your advice dave. i just wasnt sure weather their was a trick to it or not.
  4. Al.Fisherman
    Al.Fisherman New Member
    Sep 9, 2009
    1,966
    Or this......
    [​IMG] [​IMG]
    When reinstalling, super glue the key into the shaft.
  5. 2door
    2door Moderator
    Staff Member
    16,301
    26
  6. Venice Motor Bikes
    Mar 20, 2008
    6,170
    I CAREFULLY use two screwdrivers to pry it straight up.
  7. LR Jerry
    LR Jerry Active Member
    Dec 19, 2011
    1,027
    Probably one of the most important things I've learned over the years is: if its going to be more than a one time thing, invest in obtaining the proper tool.
  8. DaveC
    DaveC Member
    Jul 14, 2010
    970
    There are also battery terminal pullers for the older top post auto batteries. A large auto parts store would have them with the battery accessories, at least they do here at O'Riley's Auto Parts in the US :) They just look like a smaller version of the puller I posted above.
  9. killercanuck
    killercanuck New Member
    Dec 17, 2009
    1,749
    Lots of great options. Don't forget to put it back on the same way, mark which is "out". Otherwise it won't run.
    gl.
