How to eliminate gas/oil mixing
Discussion in 'Motorized Bicycle General Discussion' started by Prasinos, Dec 14, 2009.
  1. Prasinos
    Prasinos New Member
    Dec 1, 2008
    257
    hey fellas, what mods would have to be done to allow me to add pure gasoline into the tank? Would it be difficult to add an oil injection system?
  2. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    o_O ...good question
    I suppose one could be adapted from an existing setup, but to be honest that's one labor saving device I simply can't trust.
    Should be interesting to see what people come up with tho (^)
  3. Venice Motor Bikes
    Mar 20, 2008
    6,228
    32
    I kinda look at it like this, you'll be doing 100+ hours of R&D + cost of parts, just to save yourself the 10 seconds it takes to shake some gas!
  4. Prasinos
    Prasinos New Member
    Dec 1, 2008
    257
    so its pretty difficult... Id still be interested in how the systems work anyways.
  5. Bikeguy Joe
    Jan 8, 2008
    11,529
    It's easy, buy a four stroke.
  6. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    The oil injection on my Yamaha has an oil pump that's driven by a gear on the crankshaft, and drips oil directly on the crank bearing.
    It would be possible to add oil injection to an HT, but in doing so, you would essentially be redesigning the crankshaft and engine case.
  7. Venice Motor Bikes
    Mar 20, 2008
    6,228
    32
    DING DING DING DING!!! We have the correct answer!! (^)
  8. Egor
    Egor New Member
    Jan 30, 2008
    714
    The tank and the injection line would be easy, the pump would be the ketch. I added one to a Honda CR engine is was running in a Trail bike. The pump runs off the crank with a gear, could be done with a small belt. The throttle cable has two pulls one goes to the carb and the other goes to the pump. The pump has to be adjusted all the while as engine changes speed and throttle position. It is simple to just add oil to the gas but with the injector it seems like you never need to fill the tank with oil, it lasts forever. Could be done but I don't think it would justify all the work to install. Have fun, Dave
