How many miles before clutch pads needs replacing
Discussion in 'Motorized Bicycle General Discussion' started by Motorbikenewb, Oct 15, 2013.
  1. Motorbikenewb
    Motorbikenewb New Member
    Mar 19, 2013
    52
    Greetings,
    Finally got my second bike up and running. Could never get the first one started. Had to replace the core engine. Must have been the spark coil or magneto.
    Anyway, with normal use, how many miles before the clutch pads needs replacing?
    Thanks and have a great day.
    brnot
  2. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,568
    59
    a lot of variation on that due mostly to how the rider uses the clutch
    usually last about a year with careful riding, but I've seen them wear out in a few months (usually less than $10 for new pads tho)
  3. 2door
    2door Moderator
    Staff Member
    16,304
    29
    Ditto:
    I have three bikes with well over a thousand miles on the original clutch friction pads. Riding style will have a lot to do with the longevity of the pads. If you like to try motorcycle starts from a dead stop and 'slip' the clutch a lot, naturally that will shorten their life span but pedaling up to speed, about 10mph before engaging the clutch will make them last much longer.
    I'm sure that pad quality plays into it too. I've been fortunate and had good luck with my engines but as Crassius said, there have been reports of premature pad wear from some members.
  4. dodge dude94
    dodge dude94 New Member
    Jun 8, 2012
    1,017
    I think body weight and terrain hurts them too. If that engine is having more stress put on it, the clutch has more stress as well.
  5. Wickedest1
    Wickedest1 Member
    Oct 31, 2012
    686
    Indeed the are tons of factors...experiment with othrr materials too...friction materials r out there...
  6. Stormsorter
    Stormsorter New Member
    Jun 10, 2010
    119
    As others have said it's random. I have 2000-3000 miles on a stock orange set. They have outlasted the engine. Adjust the clutch properly, get up to 10mph before engaging it and the pads should last a long time. Almost forgot, I lapped my friction plate to a nice shine with 600 grit sandpaper. That probably helped a bit.
    And don't forget to clean the pads and plate now and then. Rubbing alcohol works great for them.
  7. maniac57
    Oct 8, 2011
    4,486
    I think it has a lot to do with how you use the clutch.
    I have never had a single clutch issue in my chinagirl career, but I have seen some customer bikes with worn out pads. It's almost always the new riders or the hot rods who have clutch problems.
    The older guys with lots of miles just don't wear them out. I've seen over 10k on one HT clutch with a 230lb rider, a tuned pipe, and a 36tooth sprocket with no pad wear problems.
    Just my opinion
  8. Wickedest1
    Wickedest1 Member
    Oct 31, 2012
    686
    Its gold...you've got tons of exp. thanks bro
