How fast will a beach cruiser with 49cc 4 stroke motor go with a 155ib user on it?
Discussion in 'Motorized Bicycle General Discussion' started by athletichunta, Aug 13, 2010.
  1. athletichunta
    athletichunta New Member
    Jul 22, 2010
    114
    Thanks so much.
  2. athletichunta
    Jul 22, 2010
    114
    Thanks so much.
  3. bairdco
    Aug 18, 2009
    6,398
    49
    Re: How fast will a beach cruiser with 49cc 4 stroke motor go with a 155ib user on it
    if you rode it off a 2000' cliff, you would reach terminal velocity right before you hit the ground, and would be going about 117-125mph when you hit. approximately...:)
  4. ferball
    ferball New Member
    Apr 8, 2010
    599
    Probably faster than it should....
  5. 2door
    2door Moderator
    Staff Member
    16,308
    32
    He might be right but I was thinking more like mach 1.2...or there abouts :)
    In all serniousness you question is impossible to answer with any degree of accuracy. There are so many variables involved that we can only make educated gusses. The engines, although outwardly appearing identical, often display quite different performance levels. Anyone with more than a couple of engines will tell you that they all run different. I have one that will run circles around my others and the only difference I've found is ignition timing. The magneto rotors (magnets) are sometimes indexed differently on the crankshaft therefore advancing or retarding the spark. Other variables are rear sprocket size, tire diameter and inflation pressure, drive train alignment, Fuel/oil mix, altitude, rider weight and, it might sound funny but his/her width. More frontal area means slower speeds.
    All in all 25 to 30 is a safe guess. Some have reported higher and lower top speeds but the 25/30 range is a good ball park figure.
  6. The_Aleman
    The_Aleman New Member
    Jul 31, 2008
    2,658
    Stock engine with stock 44T gear on a 26x2.125" wheel, probably just under 30MPH. Every 2-stroke with stock gear I've had (all were 66cc) topped out under 30. The 49cc can rev a little higher tho. For every 1 tooth smaller rear gear, you gain about 1mph.
    I ran a 34T on my first motored bicycle which gave it a top speed of ~38mph (could go faster if I wanted to overrev) and a great cruising speed of 28-30. YMMV.
  7. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    0.03284257545 mach
    440 inch per second
    21.724406048 knots
    402.336 hectometer per hour
    Or my personal favorite,
    67199.8668 furlongs per fortnight
  8. athletichunta
    Jul 22, 2010
    114
    huh? how so?. thanks
  9. athletichunta
    Jul 22, 2010
    114
    I won't be riding my bike off a cliff lol, but thanks anyway.
    I was underthe impression that 4 strokes can go alot faster than 2 strokes.
    I had a 2 stroke and it went 28 mph with me on it when i was use to be 160.
    I was thinking 37/40mph
  10. scotto-
    Jun 3, 2010
    6,530
    6
    Faster than mine, that's for sure....I'm 181 right now. But mine will max at about 34mph with a 44t rear sprocket on flat ground with a (20+ mph) tail wind....on a good day......a very good daylaff
    A lot of it really depends on the throttle position however.....the air pressure in your tires also makes a bit of difference....many factors and not all 49cc 4-stroke engines are created equal, nor are their transmissions. Is it a Honda or a HuaSheng? Or maybe some other manufacturer? What size tires are you running? Straight pipe or muffler? Altitude? A fairing perhaps? Gearing?
    #10 scotto-, Aug 14, 2010
  11. scotto-
    Jun 3, 2010
    6,530
    6
    Read your post above in Motorized Bicycle General Discussion.....no one can tell you the exact answer as there are too many factors involved.....really.
    For all intents and purposes though, 2door Tom's got you pretty well covered, seriously. But then so does everybody else for that matter.....furlong's per fortnight, you gotta love that! Isn't that the best way to measure the speed of ants.....me thinkslafflaff
    #11 scotto-, Aug 14, 2010
  12. 2door
    2door Moderator
    Staff Member
    16,308
    32
    My eyes aren't what they used to be so I missed the "4 stroke" reference. However it doesn't change my original answer except to ignor my comment about "fuel/oil mix". The other factors remain the same...sorry for the oversight.
  13. Allen_Wrench
    Feb 6, 2010
    2,787
    It really, truly, depends who's doing the asking. If a police officer is asking, I say 25 mph (being that this is the fastest speed they are allowed to go in this state). If it is a stranger, I say 25 mph (he might be an off-duty cop). If it is a trusted friend who can keep a secret, I say "I don't really know. The bicycle speedo is as accurate as an educated guess. Hey, you wanna get in your car and pace me? Maybe the speedo in your old Yugo is a little more accurate." Who really can say exactly how fast they go. Even a calibrated police radar gun isn't as accurate as they'd like you to believe. Sure a radar may be more accurate than almost anything, but if you wanna split hairs - even a GPS won't get you right on the money, it'll be really super close though.
  14. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,646
    65
    Kit engine, around 30/35.
