How do YOU go from a standstill?
Discussion in 'Motorized Bicycle General Discussion' started by jji7skyline, Jan 24, 2013.
how do you do it?
  1. I pedal a bit first, then drop the clutch. I don't want to wear my clutch.
    78.0%
  2. I REV THE ENGINE, SLIP THE CLUTCH, AND TAKE OFF AT MONUMENTAL SPEED!
    7.3%
  3. I slip the clutch sensibly.
    14.6%
  4. I never stop, so this doesn't apply to me.
    4.9%
  5. What's a clutch?
    7.3%
Multiple votes are allowed.
  1. jji7skyline
    jji7skyline New Member
    Jan 15, 2013
    114
    Tell us how you get your MB going from a standstill?.duh.
  2. lksdG2
    lksdG2 New Member
    Sep 30, 2012
    91
    i typically give about a half pedal just to get a little momentum up before i start slippin clutch
  3. azbill
    azbill Active Member
    May 18, 2008
    3,367
    I just twist the throttle !!!
    (99cc, centrifugal clutch, 72t rear sprocket) ;)
  4. livesteamfan
    livesteamfan Member
    Oct 24, 2009
    126
    Step on the belt tensioner and give it throttle. (5.5 Honda GX160 belt drive)
  5. Groove
    Groove New Member
    Nov 2, 2012
    245
    I give it some momentum then start slipping the clutch. Giving these things momentum is kind of a struggle because they're so heavy and the seat is not positioned all that well for pedaling. That's why stop signs are such a pain. I tend to roll through them..
  6. Venice Motor Bikes
    Mar 20, 2008
    6,228
    32
    The clutches in the 2-stroke engines will last forever if you pedal first then gently let out the clutch & give it some gas without slipping it.
  7. 2door
    2door Moderator
    Staff Member
    16,310
    Ditto.
    But the OP didn't say what engine or clutch. A 4 stroke with a lot of low end torque and a centrifugal clutch might not require much pedaling. Nevertheless, they aren't motorcycles.
  8. jji7skyline
    Jan 15, 2013
    114
    I've always thought that 2-strokes have more high-end power and 4-strokes had more low-end torque (though not as much as a diesel), but that doesn't seem to be the case?
  9. livesteamfan
    livesteamfan Member
    Oct 24, 2009
    126
    No, you're right. The 2-strokes make most of their power in the high RPMS while the 4-strokes have their power in the low-end. Being I have a 4-stroke, I can take off with the engine idling, my friend that has a 2-stroke has to help it to get going.
  10. Nashville Kat
    Nashville Kat Active Member
    Apr 20, 2009
    1,442
    6
    I want that good high end though never push it there- so I guess I'm really after a cruise that's nice without revs or vibration-
    50cc and 66 China girls- the 50 obviously needs more assistance, but its a 39 as opposed to a 34 on the back of the other
    The bike is light and rolls- so I'm not afraid to get up on the pedals and turn them-
    42x 22, and 40 x 22 fine alloy 3 piece vintage road cranks with just the inner chainring and a single back freewheel is what I'm running now on the pedals- so it rolls very easy- easier than a lot of normal bikes
    #10 Nashville Kat, Jan 24, 2013
  11. Greg58
    Greg58 Well-Known Member
    May 1, 2011
    2,937
    90
    I always pedal to start off, I have about 1100 miles on my grubee 48cc with original clutch pads. The lugging of the engine is just about as bad on bearing as anything.
  12. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
    I pedal to get it rolling then:
    On my Point Beach give it gas and go. It has an EZM powerplant.
    On my Atlas I ease the clutch out and match the speed with the throttle to get the clutch to lock up smoothly and then I gas it for maximum acceleration to warp speed. It has an unknown brand 66cc chinagirl power plant. Top speed, mach 0.04.
  13. Kioshk
    Kioshk Active Member
    Oct 21, 2012
    1,153
    I broke my left leg in November; upgraded my 44T to a 56T on my 66cc (with 29" wheels). Needed to be able to take off from a dead-stop and take hills without assistance (all 320-pounds of me (backpack included)). Working out swimmingly!
  14. bigbutterbean
    bigbutterbean New Member
    Jan 31, 2011
    2,417
    When I drove an ht bike, I always pedaled before letting the clutch out. If I didn't, my engine would stall (44t rear sprocket, 280lb rider). But I'm in the process of building a bike with a 98cc Lifan, and I'm not yet sure if this bike will have the necessary torque to pull me from a dead stop. Even if it does, I may still give a bit of a pedal before giving it gas, because I know that will be less hard on the clutch.
  15. Powertool
    Powertool Member
    Jul 8, 2012
    230
    pedal to set the bike in motion = 5mph. then dump the clutch
  16. 16v4nrbrgr
    16v4nrbrgr New Member
    Mar 17, 2012
    1,718
    My OCC with 44t and a 66 HT allowed pushing off without pedaling with a little slip, and had about a 30-32 top speed.
  17. wasiss
    wasiss New Member
    Jan 16, 2013
    6
    I found that if i ride by the lights ahead i don't have to come to a full stop but if i have to i get on the ped's for about 10 feet then start l
    etting out on the clutch.
  18. CTripps
    CTripps Active Member
    Aug 22, 2011
    1,311
    I pedal, rev, release, and rock and roll. (^)
  19. rudyauction509
    rudyauction509 New Member
    May 8, 2012
    160
    I used my clutch like a motorcycle's clutch and never pedaled off to start and it lasted the life of the motor: 6,000 miles. Then the side of the cylinder somehow exploded at 30 mph destroying the whole motor.
  20. Groove
    Groove New Member
    Nov 2, 2012
    245
    That sucks! LOL though... Did you install a new motor yet??
