How do I use this Speeco chain breaker
Discussion in 'Motorized Bicycle General Discussion' started by geoldr, Aug 24, 2011.
  1. geoldr
    geoldr New Member
    Jun 19, 2011
    260
    Hey guys, so I bought #41 chain from a lawn mower shop, but I cant fit it. I don't have the proper chain tools. I have a motorcycle chain breaker which works extremely well for the original chain, but it doesnt fit this one. I broke my bicycle chain tool with this chain. So I went to the place I got the chain and they ordered me one of these:
    [​IMG]
    How do I use this??? The pin is way too small to to push the roller all the way out.
    I have work in an hour so I cant go to the shop to ask them. so I figure I will post here in the meantime.
  2. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
    Those things work great.
    First dremel off both pin heads on a side plate.
    Then use the tool to push the pins through the side plate.
  3. geoldr
    geoldr New Member
    Jun 19, 2011
    260
    This thing requires a dremel?? None of my other chain tools did. Whats the point of the tool if I have to use a dremel? I got this tool to be able to reuse the pin, so I don't have to use any master links. Besides I have a half link that I need to put in, and it requires a full pin. So is this tool useless?
    Should have gotten one of these instead
    #40/41 Deluxe Chain Tool (604041 or 604042), www.bmikarts.com : BMI Karts & Supplies : Go Karts Parts : Racing Go Kart Parts : GoKarts : Versailles, Ohio : USA : Indoor Track : Tips
    Those look like they can push pins out and back in without any dremel
  4. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
    It's really hard to push the swedge through the side plate. It is hardened steel.
  5. geoldr
    geoldr New Member
    Jun 19, 2011
    260
    On stock chain it was really simple. Pops right out with a chain breaker that has a long pin.
  6. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
    I have no idea about what you have used or on what.
    I have one of those chain breakers that you have pictured and I have used it on many different sizes of chain. With a dremel first to grind the pin flush with the side plate. And always with a master link.
    Anything else, I can't help you with.
  7. Venice Motor Bikes
    Mar 20, 2008
    6,228
    32
    If all you need to do is shorten the chain?, all you need to do is grind down the end of the link pin & pry the link apart. ;)
  8. killercanuck
    killercanuck New Member
    Dec 17, 2009
    1,749
    I use a breaker like pictured for the initial break, then what's left of a cheapy white metal "breaker" to push the pin out. I've found if you can't get the claws to grip properly, you can squash the link with a vise-grip so it'll fit properly.
