How do I make a new bucking bar
Discussion in 'Motorized Bicycle General Discussion' started by nathanmd33, Jan 29, 2014.
  1. nathanmd33
    nathanmd33 New Member
    Sep 23, 2013
    45
    So my bike eventually started! I have ridden a lot on it! It had some problems so I had to re mount and must have lost the bucking bar. Does anyone know how to make a new one?
    I have a 80 cc motor bike
    I live in Athens/watkinsville Georgia
    Am 15 with a learners permit
    I enjoy making stuff like this
    can I legally drive around? (have been doing)
    Thanks!
    .duh.
  2. Agreen
    Agreen Member
    Feb 10, 2013
    787
    Not sure what a bucking bar is. Google says it's the block you put behind a rivet to set it.
    And most places require you to have a license of some sort, so check your laws. An easy internet search will tell you all you need to know. Also, make sure your ride is legal. SC law here says I have to have working brake lights when either brake light is depressed, a head light, tail light, and functional turn signals. Also have to have a rear view mirror, can't go over 25 mph, no more than 2 horses, and can't physically make the moped go over 30 on a flat surface.
  3. 2door
    2door Moderator
    Staff Member
    16,308
    30
    The bucking bar length is critical. That's the problem with making a new one without your original for comparison.
    As for making one; if you have a way to cut it, a 5/16" or an 8mm drill bit works well. The ends need to be slightly rounded and smooth. You can use softer steel but it will wear faster. The shank of a drill bit is best but you could also use a hardened bolt, grade 8 works well too.
    I don't have an exact length to offer you right now but something close to an inch and a quarter will get you in the ball park.
    If you lost the bucking bar you might have also lost the ball bearing that goes in before it. It too is 5/16" or 8mm. Both parts and the cam in the clutch actuator cover need to be lubricated with a good grade of bearing grease prior to reassembly.
  4. MotorBicycleRacing
    Jul 28, 2010
    5,717
    35
    The bucking bars on my motors are 1.046" long.
    I also carry a longer bar that is 1.103" long.
  5. nathanmd33
    Sep 23, 2013
    45
    I cut a bolt that was 5/16 to 1" popped it in there with some lube and It worked! thanks everyone 2door and wingnut!
    I would upload a pic of the cut bolt but I cant figure it out. my pictures are too big?
  6. 2door
    2door Moderator
    Staff Member
    16,308
    30
    I wouldn't have thought 1" would have done it but we're sure glad you have it fixed.
    Have fun and ride safe.
  7. Greg58
    Greg58 Well-Known Member
    May 1, 2011
    2,927
    89
    To post pictures from your phone you need to download a photo editor app, resized pictures to 1024x768 pixels will upload from my phone. After resizing the photo save it to your pictures.
    #7 Greg58, Jan 29, 2014
  8. Jumpa
    Jumpa New Member
    Aug 12, 2011
    607
    to quickly rsize images I go to the picture right click it open with paint then I go to tools then attribudes and enter the proper value required for what ever application calls for or you can just use http://imgur.com/ they should do it automaticly
