How about this as an exhaust?
Discussion in 'Motorized Bicycle General Discussion' started by Mind_Reader7, Oct 4, 2010.
  1. Mind_Reader7
    Mind_Reader7 New Member
    May 1, 2010
    393
  2. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    I may be wrong, but I'm not sure that would be good for a two-stroke. Seems like there would be essentially zero backpressure. There's a reason the stock pipes have a cap on the end with a little hole in it.
  3. Mind_Reader7
    May 1, 2010
    393
    I've been running a straight through pipe for quite a while now, and O only have positive things to say about it. It's probably the biggest performance increase you can get from these engine.
  4. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    A straight pipe will give you some performance gain over the stock pipe, because the lack of backpressure will cause it to run leaner. However, too much lean will shorten the engine's lifespan considerably. An expansion pipe exhaust is preferable in every way to a straight pipe.
  5. Mind_Reader7
    May 1, 2010
    393
    My bike runs fine. I was actually running it somewhat rich for quite a while, and change the needle setting about a week ago.
  6. PR3C150N
    PR3C150N New Member
    Aug 27, 2010
    69
    Thats for a car?
  7. Mind_Reader7
    May 1, 2010
    393
    Yepper. It's a car exhaust. I'm still yet to find a reason not to use it.
  8. NunyaBidness
    NunyaBidness Active Member
    Jun 29, 2008
    1,062
    There has been a very good reason for NOT using it but apparently you don't want to listen to that advice. So good luck with it and I hope you don't ruin your motor too fast with it.
  9. Mind_Reader7
    May 1, 2010
    393
    No worries. I'm going to buy it. Will post pics/reults when I'm done.
  10. Mind_Reader7
    May 1, 2010
    393
    Hey, if I started this up, and had a spark at the end of the exhaust, would it shoot flames n stuff? Would be pretty cool.
  11. mobike91
    mobike91 Member
    Sep 14, 2010
    111
    cause it weights alot? a car muffler weighs like 10- 25 lbs. even cherry bombs arent that light. the expansion chamber is light, mounts easily, and increases your power band. if those dont make you want a expansion pipe then your crazy lol.
  12. PR3C150N
    PR3C150N New Member
    Aug 27, 2010
    69
    lol cant wait to see pics :=]
  13. Slowrollers
    Slowrollers New Member
    Sep 8, 2010
    65
  14. PR3C150N
    PR3C150N New Member
    Aug 27, 2010
    69
    Twin Expansion chamber looks awesome. anybetter then one?
  15. Slowrollers
    Sep 8, 2010
    65
    I have a friend that has one on his kitted motobecane (70cc) and he said it hits nicely @ around 35.....
    I think hes running polini stinger tips /baffels.....
    It looks cool and with a little welding it would be neat on a MB....
