Horn connected to engine??????
Discussion in 'Motorized Bicycle General Discussion' started by matesrates, May 17, 2010.
  1. matesrates
    matesrates New Member
    Feb 6, 2010
    93
    Is there any ways to connect a Horn to engine????
    I don't mind loosing power when horn is presszpt
    Anyone have any ideas???
  2. city of angels
    city of angels New Member
    May 24, 2009
    470
    have you try an air horn i have one on my trike and it holds about 60 psi of air and trust peopledoes hear me when i honk my horn the website where i got mine is usabikemotors.com
  3. Bikeguy Joe
    Jan 8, 2008
    11,529
    Hook it up to the white wire. 6v
  4. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    Finding a 6v horn isn't that tough - but finding one with as low an amperage/wattage as to not immediately shut off the engine might be a bit tricky. Loosing power would be fine - but I suspect it'd act as a kill switch & defeat the purpose.
    I've a vintage headlight with a horn built in, designed for a mere 3v instead of 6 it might work... but I've a generator hub so I've not tried it... for this I'd suggest batteries (headlight horn combo is common) or even an air horn like city of angles suggested *shrug*
  5. Happy Jack
    Happy Jack New Member
    Apr 18, 2010
    39
    My reply will have no solution to your horn search.
    #5 Happy Jack, May 17, 2010
  6. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    I've seen one on an old Harley but I doubt it would work on a little china girl engine. Since they work off of engine vacuum to get them to work well (even on a V8) you have to rev the engine up, close the throttle and you can get a quick WHOOO WHOO out of them before there isn't enough vacuum left.
    I have to agree with city of angels though, the AIRZOUND is one of the most effective bike horns I've ever seen.
    YouTube - AirZound vs LL08VSV
  7. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
    Those AirZound horns are loud enough to make you jump out of you skin if you are not expecting the honk.
  8. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    16
    I use the airzound and it has saved my butt several times with drivers that fall asleep at the wheel.
  9. matesrates
    Feb 6, 2010
    93
    Them generator head lights and tail lights combo
    Would a mini horn work off this instead of lights??
    This only creats very small power??
    I was thinking about putting a small 6 volt motorbike battery
    But i don't want to recharge it every time it goes flat....
    So connect it to white wire????zpt
    But then i have problem of to many amps in the battery might do damage??
    What do you think of this???
  10. matesrates
    Feb 6, 2010
    93
    Is this the one connected to a water bottle thingy????
    They look good
    How many times can you press the horn ..
    With 60psi???.trk
  11. BarelyAWake
    Jul 21, 2009
    7,209
    Probably, but I dunno for sure - I have a Sturmey Archer Dyno Hub, X-FDD: Sturmey Archer
    ...but even one of those bottle gens that run off a tire might work, it'd be worth a shot *shrug*
    The output of the white wire is so marginal I really doubt it'd do any damage, in fact I doubt it'd even manage to keep a battery topped of should you use a headlight...
  12. matesrates
    Feb 6, 2010
    93
    Hey there
    I just received my delta Ait zone horn
    Its AWSOME thanks for the tipdance1
  13. dag_29307
    dag_29307 New Member
    Jul 1, 2009
    296
  14. matesrates
    Feb 6, 2010
    93
    hey there
    I bought some led head lights and tail light
    The front is 52 led needs 3 aa batterys
    The rear 5 led needs 2 aa batterys
    Most Normal aa battery 1.2 volts each?? total 6 volts???? Some are 1.5 volt..
    So instead of buying batterys Do you think these will run of the engines white wire??zpt
    Thanks for your help
    #14 matesrates, Jun 9, 2010
  15. BarelyAWake
    Jul 21, 2009
    7,209
    Ahh - so now the (my) question would be, how to charge 12v DC accessories (like an mp3 player) off a 6v DC sys?
  16. dag_29307
    Jul 1, 2009
    296
    Gimme a little time BarelyAWake I'm working on it. I will create/find something for that.
  17. BarelyAWake
    Jul 21, 2009
    7,209
    o_O
    orly?
    dance1
    I hate tryin' to figure out electrics - "ZOT!!! ...hmm ...guess that's not it then o_O" is about the best I can do heh
  18. dag_29307
    Jul 1, 2009
    296
    Funny.. I'm no electrician either. Just a poor broke SOB that is determined to find a way. laff
    I have to I have no other way around and it's too far for me to walk anywhere here.
  19. 5446
    5446 New Member
    Jun 7, 2010
    84
    hi guys there a gizmo on ebay I think its called a mini-gen max that would help.
  20. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    Actually if your MP3 charges though a USB port/connector a USB port only puts out 5V at 500 mA.
