Holes on clutch cover and the other cover.
Discussion in 'Motorized Bicycle General Discussion' started by jototojo, May 29, 2011.
  1. jototojo
    jototojo New Member
    Apr 10, 2011
    32
    Hello people again!
    So, i saw pictures of bikes that had holes on the clutch cover and on the other cover of the other side.
    It makes any difference?
    Like cooling?
    Thanks!
    Edit/Delete Message
  2. 2door
    2door Moderator
    Staff Member
    16,301
    26
    Don't put any holes in those covers. They keep dirt and moisture out of critical moving parts. There is absolutely no cooling benefit.
    I'm not sure where you saw pictures of the covers with holes but they were not on the bikes built by experienced builders.
  3. DuctTapedGoat
    DuctTapedGoat Active Member
    Dec 20, 2010
    1,179
    7
  4. MotorBicycleRacing
    Jul 28, 2010
    5,686
    27
    Like 2door said no cooling is needed
    and the gears inside that cover are the noisiest part of the engine
    so holes will make that worse.
    I have seen the holey cover pics of bikes and they were art bikes.
    Made more for the look than function.
  5. bairdco
    Aug 18, 2009
    6,350
    25
    uhhh, i put some holes in my clutch cover. a few small ones drilled on the side in the front and rear, hoping to cool down my clutch by passing airflow through it.
    i dunno if it helped.
    BUT the bike is totally modified and the stock clutch pucks don't work with the power, and after trying every adjustment, etc i could think of, i drilled the holes.
    now i'm just gonna get some real friction material for the pucks.
  6. MotorBicycleRacing
    Jul 28, 2010
    5,686
    27
    The OP was talking about swiss cheesing the clutch cover, magneto and
    sprocket cover.
    It looks cool, I have some pics saved somewhere.....looka like a GP bike.
    You are using Chinese rubber tire sidewall clutch pads. It is some kind of
    modern day miracle that it even works!
    The red round clutch pads are a better material, maybe?
  7. DuctTapedGoat
    Dec 20, 2010
    1,179
    7
    Where do you find those at? (red round clutch pucks)
