Hi!
Discussion in 'Introduce Yourself' started by mamadou camara, Nov 17, 2009.
  1. mamadou camara
    mamadou camara New Member
    Nov 17, 2009
    Hi everybody!
    My name is Mamadou CAMARA.
    I'm new in the world of motorized bicycles.I just purchased an 80cc engine from bikeberry motors.I did mount the kit. But every time i pull the clutch(disengage the engine) the motor dies As long i throttle
    up and the engine is engaged.It runs fine.
    I need some ideas on how to fix that .
    Thank You!!!:-||
  2. Finfan
    Finfan New Member
    Aug 29, 2008
    871
    There is a screw on the side of the carb that adjusts the idle. Try adjusting that to see if it helps. Unfortunately I can't remember if you have to turn it in or out to increase the idle since I haven't touched mine for so long. Good luck!
  3. mamadou camara
    Nov 17, 2009
    Thanks FinFan i'll try that.
  4. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    16
    Welcome mamadou camara to the forum, glad you joined us.
    In to increase rpm, out to decrease.
  5. rkorson4209
    rkorson4209 New Member
    Oct 10, 2009
    251
    I had that same problem, i had to adjust the carb needle setting
  6. mamadou camara
    Nov 17, 2009
    Hey !
    I tried to adjust the idle screw.I still have the same problem.I also tried to increase the rpm(or decrease it), but nothing changed. How do you adjust the carb needle ?I'm not a crack in mechanic.But with a couple hints i might be able to find my way around.
    I think it's not electric because as long as i don't pull the clutch(disengage the clutch) it run fine.
    Another thing my kill switch doesn't seem to work.I wired it this way: yellow/red wire(from kill switch) to white wire (from engine);green wire(from kill switch) grounded to the bike frame. Any idea why it's not working.
  7. Finfan
    Finfan New Member
    Aug 29, 2008
    871
    Could be a bad switch or the engine may not be grounded to the frame. Try connecting the ground wire directly to the engine. If that doesn't work and you have an ohm meter then measure continuity across the switch. It should be open (infinite resistance) normally and go to a short (zero resistance) when the button is pushed.
    If you remove the cap from the top of the carb where the cable enters you'll find the needle. There is a metal disk on it that you can move up and down to adjust it. I think moving the disk down will increase the fuel flow.
    Good luck!
  8. mamadou camara
    Nov 17, 2009
    It's working now.The engine is idling now.I did clean the carb. But my kill switch is not working.Do i need to peel off some paint off v the bike frame the ground wire would have a better contact??Or shoud i drill a hole in the frame and screw the ground on it?:-||:-||
  9. bairdco
    Aug 18, 2009
    6,376
    37
    to get a good ground, scrape the paint off to bare metal, get a tiny lug and a tiny screw, drill a pilot hole and screw it in.
    my bike is an old cruiser that used to have a fake tank on it, and it already had a tiny hole, so i got lucky. my last bike had a head badge on it, so i used that screw.
    but the key to a good ground is a good contact, and paint doesn't help.
  10. Finfan
    Finfan New Member
    Aug 29, 2008
    871
    Or you can just wire the switch across the two wires that go to the CDI (black box with the spark plug wire). Short them together and you kill the engine.
  11. rkorson4209
    Oct 10, 2009
    251
    No it doesn't sound like an electrical problem at all. Are u using the choke to start it and then gradually turning it down, to where it eventually is off. At first i was having that problem. Then it was my carb needle setting, which is real easy to udjust. PM me if you need any specific help.
  12. mamadou camara
    Nov 17, 2009
    Hey Everybody!!
    My bike is working great now.The kill switch works every time.It's awesome!!!!
    Mighty thanks to everybody help. dance1 brnot dnut
