Hi - any advice on airing up 11" scooter tires
Discussion in 'Motorized Bicycle General Discussion' started by gaffo, Aug 27, 2014.
  1. gaffo
    gaffo Member
    May 10, 2014
    182
    Rims are around 6"? inches. Typical Goped/Razer type wheels.
    I aired up the front tire fine - to 45 psi (was around 25 psi) - but cant access the back valve-stem (due to the chain/sprocket and frame).
    Do I need a "valve extender"? - if so which type? (seems there are many types -with different threads and maybe for different vehicles-types also.
    Nothing is simple anymore ;-(.
    I'm ignorant about such things, but would sure appreciate any help on the matter.
    still need to join the 20 mph club ;-/.
  2. Theon
    Theon New Member
    Jan 20, 2014
    1,440
    Maybe easier if you remove back wheel?
  3. a.graham52
    a.graham52 New Member
    Nov 22, 2013
    232
    is there any holes you could reach through the rim? how about a picture?
  4. maniac57
    Oct 8, 2011
    4,486
    Flip the hub so the valve stem is on the other side. This may require dis-assembly.
  5. Patchy
    Patchy Member
    Aug 12, 2014
    87
    Something similar happened to me the other day when I was trying to pump up my friend's motorbike, the front tire's valve was stuck at an angle and the pump head couldn't get pressure into the tire, had to deflate the tire and adjust the inter tube. You might just have to do that man.
  6. gaffo
    gaffo Member
    May 10, 2014
    182
    Like to thank all who replied.
    I figured it out. bought some metal valve-extenders and screwed 2 together to make it long enough to reach the tire-valve through the chain-sprocket assembly.
    aired up the 15 psi tire up to the recommended 45 psi using simple bike hand pumb.
  7. azbill
    azbill Active Member
    May 18, 2008
    3,367
    some of the go-peds have the valve extender in one handlebar grip ;)
