HELP with SPROCKET bolts and brake arm at hub
Discussion in 'Motorized Bicycle General Discussion' started by Goergedave, Oct 26, 2015.
  1. Goergedave
    Goergedave New Member
    Oct 23, 2015
    35
    The bolt heads get in the way of the arm so it won't spin freely. I don't have a vice to properly bend it. I was thinking some bolts that use an allen wrench to tighten them, that have flatter heads. Other suggestions and LINKS are appreciated.
  2. YesImLDS
    YesImLDS Member
    Jun 29, 2013
    955
    Easiest thing to do would go somewhere you can get it bent slightly. Sounds like you are trying to over complicate the solution. You could try your other solution but it's not guaranteed to work so you may be spending unnecessary money. Are you sure there is no way you can bend it? Get creative you don't need a vise! Try some vice grips!
  3. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,720
    82
    find a place on the sidewalk that is raised an inch or so, put arm there & smack it good with a hammer
  4. bailsafe
    bailsafe New Member
    Oct 23, 2015
    71
    Aha, this. I had to do this with my brake arm since I lack a vice grip.
    On a side note, make sure your sprocket and pads are centered almost perfectly, the slightest deviation can cause some issues with the brake arm if you're not careful
  5. Slogger
    Slogger Member
    Sep 8, 2014
    545
    I had trouble bending the exhaust header and put a small divit in it.
    Motorizing bikes requires a lot of grinding, bending, and adapting to deal with this stuff.
    It just goes with the territory, I guess.
    When it's done you'll be proud to say you made it work.
  6. maniac57
    Oct 8, 2011
    4,486
    Best fix is to not use coaster brake rims. Freewheel rims last longer and are MUCH easier to assemble. Simply add hand brake.
    And easy fix for exhaust woes is drilling out flange holes. This allows pipe to turn for clearance. I have never yet had to bend an exhaust with this trick
  7. Bikeguy Joe
    Jan 8, 2008
    11,529
    You may get away with using carriage bolts.
    I did it on one bike, worked fine.
  8. YesImLDS
    YesImLDS Member
    Jun 29, 2013
    955
    Also if it isn't perfectly aligned it will cause a tighten and slack sort of problem on your chain. You think it's on there nice and snug, but on the other side of the wheel it'll be slack enough for it to fall off.
